iLogic-Using loops for feature suppresion
edgar123trejo
edgar123trejo
Really new to using iLogic. Is there a template or explanation for one to use a loop instead of IfElse for feature suppression? I am trying to keep my code short without alot of copy and pasting.
JaneFan
Please take the following code in iLogic as reference:
SyntaxEditor Code Snippet
Dim oFeat As PartFeature
For Each oFeat In ThisDoc.Document.componentdefinition.features
	If oFeat.Suppressed = False Then
		oFeat.Suppressed = True
Next
Jane Fan
Inventor/Fusion QA Engineer
edgar123trejo
Sorry about this but may you further explain was the syntax means?
I modeled a door and i am programming sizes for it. The smaller sizes have some features turned off. How will the syntax work to go back and forth for suppressing and unsuppressing  the features when changing sizes?
Thank!
JaneFan
It seems no loops needed since some certain features need be suppressed in case of some certain parameters change. Does the following code work for you?
If d1 < size Then
	Feature.IsActive("featurename1") = False
	Feature.IsActive("featurename2") = False
Else
	Feature.IsActive("featurename1") = True
	Feature.IsActive("featurename2") = True
Jane Fan
