E_FAIL error on PackAndGo ProjectFile assignment in .NET 8 Add-in
cgtyklsn
Message 1 of 9
cgtyklsn
I’m using Inventor 2025 and have an add-in project built with .NET 8.
I converted the PackAndGo example code from this article:
https://adndevblog.typepad.com/manufacturing/2013/05/use-packandgo-of-2014-api.html
to C# and tried to use it in my add-in. However, when assigning the ProjectFile property, I get the following error:
{"Error HRESULT E_FAIL has been returned from a call to a COM component."}
The same code works without issues in a Windows Forms app built with .NET Framework 4.7.2.
Any advice or experiences would be appreciated. Thanks in advance!
Replies (8)
Message 2 of 9
CGBenner
@cgtyklsn
Welcome to the Community.  I have moved your post here to the Programming forum so the experts can try to help you with your question.  Good luck!
Chris Benner
Message 3 of 9
CGBenner
@bradeneuropeArthur Is this something that you might be able to help with?
Chris Benner
Message 4 of 9
bradeneuropeArthur
Could you share your code. This makes it easier for me!thanks
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 9
cgtyklsn
I already shared the link to the code in the post. Had you looked at it? @bradeneuropeArthur
Message 6 of 9
bradeneuropeArthur
Is that exact the same code you use?
   Public Sub main
        Dim oPacknGoComp As New PackAndGoLib.PackAndGoComponent
        Dim oPacknGo As PackAndGoLib.PackAndGo
		Try
		MkDir("C:\Temp\PackandGo")
		Catch
		End Try
        oPacknGo = oPacknGoComp.CreatePackAndGo(ThisDoc.Document.FullFileName, "C:\Temp\PackandGo")
        'oPacknGo.ProjectFile = "D:\Files\Inventor Projects\"
        Dim sRefFiles = New String() {}
        Dim sMissFiles = New Object
        oPacknGo.SkipLibraries = True
        oPacknGo.SkipStyles = True
        oPacknGo.SkipTemplates = True
        oPacknGo.CollectWorkgroups = False
        oPacknGo.KeepFolderHierarchy = True
        oPacknGo.IncludeLinkedFiles = True
        oPacknGo.SearchForReferencedFiles(sRefFiles, sMissFiles)
        oPacknGo.AddFilesToPackage(sRefFiles)
        oPacknGo.CreatePackage()
    End Sub
This will do from within Inventor!
Let me know your thoughts.
@CGBenner @cgtyklsn
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 9
cgtyklsn
Message 8 of 9
CGBenner
@cgtyklsn
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Message 9 of 9
cgtyklsn
A solution to this problem has not yet been provided.
