Duplicate error !
Duplicate error !
Duplicate error !
I tried to run a sub for both part and assembly documents using this select
case and I got this mesg
Anyone helps, pls.
Thx
Select Case ThisApplication.ActiveDocumentType
Case Is = kPartDocumentObject
Dim oDoc As Inventor.PartDocument
Case Is = kAssemblyDocumentObject
Dim oDoc As Inventor.AssemblyDocument
End Select
IV11 Pro. sp1 - uninstalled
Window XP Pro sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400 84.26
SpacePilot V 1.1.2
You can't conditionally dimension a variable as
two different types in VB6.  Just dimension oDoc
As
Inventor.Document generically then
based upon the ActiveDocumentType use the
appropriate properties or methods of that document subtype.
Also, "Case Is =
kPartDocumentObject
" is unnecessary.  Instead, simply use "
face="Courier New">Case kPartDocumentObject
Brian R.
Iwaskewycz
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">CAD Systems
Manager
href="http://www.corefurnace.com">Core Furnace Systems
