Select Case Problem
Select Case Problem
isocam
Select Case Problem
isocam
I have a problem with select case that I hope somebody can help me with.
I have a variable "NumberOfEntities"
If the Counter is 1 then one thing happens
If the Counter is greater than 1 but less than NumberOfEntities then another thing happens
and finally.....
If the counter is equal to the NumberOfEntities then I want the programme to do something else
But I cannot get the programme to work.
Can anybody help?
Here is my code.......
NumberOfEntities = 7
For Counter = 1 To NumberOfEntities
Select Case Counter
Case 1
MsgBox Counter, 64, "Counter is 1"
Case Is > 1 And Counter < NumberOfEntities
MsgBox Counter, 64, "Counter is greater than 1 but less than NumberOfEntities"
Case Is = NumberOfEntities
MsgBox Counter, 64, "Counter is equal to the NumberOfEntities"
End Select
Next
Kind Regards
Darren
Try:
For Counter = 1 To
NumberOfEntities
  Select Case Counter
Case 1
         MsgBox Counter, 64,
"Counter is 1"
    Case
NumberOfEntities
         MsgBox
Case Else
NumberOfEntities"
  End Select
Next
Brian R.
Iwaskewycz
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">CAD Systems
Manager
href="http://www.corefurnace.com/">Core Furnace Systems
You can also use the 'To' operand to specify a range of values.
[code]
Private Sub Command1_Click()
Dim a As Integer
a = 62
Select Case a
Case 1
MsgBox "A = 1"
Case 2 To 63
MsgBox "A = " & a
Case 64
MsgBox "A = Top Value"
End Select
End Sub
[/code]
