VB add Inventorviewcontrol
I got a question about the inventorviewcontrol. I'm using it in VB6, but don't know how to insert it at runtime. I tried the following:
dim oView as InventorViewControl
sub blablabla()
'This doesn't work!
Set oView=New InventorViewControl
end sub
Why doesn't this work? And what can I do to make it work?
You may add a new form, and insert InventorViewControl into this form from
toolbox, then you can use it in this form.
In sub you can show this form.
дÈëÓʼþ news:5208413@discussion.autodesk.com...
sub blablabla()
'This doesn't work!
end sub
Thanks, but it doesn't help. What I actually try is to update the view of the inventorviewcontrol, by removing it and placing it back.
This because i don't know how to update the control. Does someone know how to update the inventorviewcontrol?
(Or perhaps another trick to update it's view?)
Ralf
Place it on the form, not visible until you need it, then make it visible.
Joe
wrote in message news:5208516@discussion.autodesk.com...
Ralf
Yes, but if i make it invisible and then again visible, it still hasn't updated.
I only want to know how to actually update the inventorviewcontrol.
Who knows how to do this?
