Duplicate Command Bar Buttons
I am writing an AddIn that adds a button to a command bar.  Each time I run the AddIn it adds another button.  How do I either clear the command bar or add the button so that it is not duplicated each time I debug it?
Activate function
        Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
            ' This method is called by Inventor when it loads the AddIn.
            ' The AddInSiteObject provides access to the Inventor Application object.
            ' The FirstTime flag indicates if the AddIn is loaded for the first time.
            ' Initialize AddIn members.
            m_inventorApplication = addInSiteObject.Application
            'Get the ClassID for this add-in and save it in a
            'member variable to use whenever a ClientID is needed
            m_ClientID = "{7ff8d131-439f-469e-9a66-4531beab12c4}"
            'Create a new toolbar and make it visible
            If firstTime Then
                GetOrAddCommandBar()
            End If
            ' TODO:  Add ApplicationAddInServer.Activate implementation.
            ' e.g. event initialization, command creation etc.
        End Sub
 GetOrAddCommandBar function
        Private Sub GetOrAddCommandBar()
            'Variable declarations
            Dim cmdBar As Inventor.CommandBar
            Dim smallicon As stdole.IPictureDisp
            Dim largeicon As stdole.IPictureDisp
            'Set command bar to nothing
            cmdBar = Nothing
            'Attempt to get the existing command bar
            Try
                cmdBar = m_inventorApplication.UserInterfaceManager.CommandBars.Item("CP AddIns")
            Catch ex As Exception
            End Try
            'Check to see if the existing command bar was found.
            If cmdBar Is Nothing Then
                'Create a new command bar
                cmdBar = m_inventorApplication.UserInterfaceManager.CommandBars.Add("CP AddIns", "CP AddIns")
            End If
            'Convert icon
            smallicon = PictureDispConverter.ToIPictureDisp(My.Resources.cmdButtonIcon)
            largeicon = PictureDispConverter.ToIPictureDisp(My.Resources.cmdButtonIcon)
            'Create button definition
            m_cmdButtonDef = m_inventorApplication.CommandManager.ControlDefinitions.AddButtonDefinition("Print A Size", "PrintASize", _
            Inventor.CommandTypesEnum.kQueryOnlyCmdType, , "Print A Size", "Print A Size", smallicon, largeicon, ButtonDisplayEnum.kDisplayTextInLearningMode)
            'Add the button
            cmdBar.Controls.AddButton(m_cmdButtonDef)
            'Make the command bar visible
            cmdBar.Visible = True
        End Sub
 Also, how do I force the AddIn to use the 16x16 icon instead of the 32x32 one?
Found my problem.  I was adding the button regardless if the command bar was found or not.  Programming error.
