Method 'Reorder' for Demoting Pattern to New Sub-Assembly Fails
jacofiero
jacofiero
I'm trying to automate the creation of a new subassembly and demote a circular occurrence pattern to it.  I can do it, manually, without incident but the VBA macro kicks out an error.  I set SilentOperation = True, but VBA still kicks out the error and my pattern doesn't get demoted.
Here's the code.  I'd appreciate any help.
Public Function TESTDemoteDeck()
    Call InitializeMainObjects
    Dim oNewSubAssy As AssemblyDocument
    Set oNewSubAssy = oApp.Documents.Add(kAssemblyDocumentObject, , False)
    Dim oMat As Matrix
    Set oMat = ThisApplication.TransientGeometry.CreateMatrix
    Dim oSubAssyOcc As ComponentOccurrence
    Set oSubAssyOcc = oAsmCompDef.Occurrences.AddByComponentDefinition(oNewSubAssy.ComponentDefinition, oMat)
    Dim oPane As BrowserPane
    Set oPane = oDoc.BrowserPanes.Item("Model")
    Dim oSubAssyNode As BrowserNode
    Set oSubAssyNode = oPane.GetBrowserNodeFromObject(oSubAssyOcc)
    ' Get the last visible child node under the sub-assembly occurrence
    Dim oTargetNode As BrowserNode
    Dim i As Integer, j As Integer
    For i = oSubAssyNode.BrowserNodes.Count To 1 Step -1
        If oSubAssyNode.BrowserNodes.Item(i).Visible Then
            Set oTargetNode = oSubAssyNode.BrowserNodes.Item(i)
            Exit For
    Next
    Dim oSourceNode As BrowserNode
    Set oPattern = oAsmCompDef.OccurrencePatterns.Item("PatternName")
    Set oSourceNode = oPane.GetBrowserNodeFromObject(oPattern)
    oApp.SilentOperation = True
    On Error GoTo CheckError
    '##ERROR FROM THE LINE BELOW THIS
    Call oPane.Reorder(oTargetNode, False, oSourceNode)
    oApp.SilentOperation = False
CheckError:
    Debug.Print "!!!!Run-time Error!!!!"
    Debug.Print "    Err.Number = " & Err.Number
    Debug.Print "    Err.Descri = " & Err.Description
Resume Next
End Function
 Most of it is taken directly from the code example in the API Help reference
Oh, here's the error.  I believe it's just a generic automation runtime error.
Err.Number = -2147467259
Err.Descri = Method 'Reorder' of object 'BrowserPaneObject' failed
MjDeck
Although you can use BrowserPane.Reorder to demote a component into a subassembly, it doesn't work for a component pattern. We should be able to make it work in a future version.
Mike Deck
Software Developer
Autodesk, Inc.
jacofiero
Fair enough. Thanks for the reply.
