DrawingCurvesEnumerator
Ralf_Krieg
Advisor Advisor
Ralf_Krieg
Hello
To reproduce please do the following in Inventor 2011:
- create a sheet metal part (a simple face is enough)
- create a sketch on the face and put a rectangle on it
- make a FlatPattern
- mark the sketch as CopyToFlatPattern
- create an IDW and put a FlatPattern BaseView on it
- include the sketch
- run the following code in VBA-Editor to see, that the sketch lines are not included in the DrawingCurvesEnumerator
Option Explicit
Private Sub test()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oCurveEnum As DrawingCurvesEnumerator
Set oCurveEnum = oDrawDoc.ActiveSheet.DrawingViews.Item(1).DrawingCurves
MsgBox "count: " & oCurveEnum.Count 'says 4, instead of expected 8
End Sub
Bug or "as designed"? Or my fault? Edited by: krieg on Mar 27, 2010 12:56 PM
R. Krieg
RKW Solutions
www.rkw-solutions.com
I was able to reproduce the issue, and I've filed this in our database with
high priority. If you select the drawing curve in the UI, the API does
report it correctly in Document.SelectSet. However, the DrawingCurves
collection doesn't report it.
Thanks for reporting this.
Sanjay-
