- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to automate the drawing-creation in our company. Steps I've taken:
- create new drawingdocument with template
- Save new drawingdocument
Problem:
Creation of new document works, but the next step, saving it to a specific location, fails. Error handler is initiated and displays error: Invalid procedure call or argument.
Used code:
Dim DXF_DWG as DrawingDocument 'Create new drawing based on template Set DXF_DWG = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, ThisApplication.FileOptions.TemplatesPath & "\Folded and Flatpattern DXF.dwg", True)
'Save new drawing to specific location Call DXF_DWG.SaveAs("C:\Temp\Test.dwg", False)
As told, the VB-code raises an error on the last command. What am I doing wrong? What are the correct steps in VBA to create a new drawing document based on a template and save the newly created drawing to a desired location?
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 10 Professional (64bit)
