Assembly current view
Message 1 of 10
Is it possible to know if the assembly view is isometric view or not.I need to perform check to get this value.
Sheena
Replies (9)
Message 2 of 10
ekinsb
Are you talking about a view of an assembly in an drawing or the current view of an assembly when working on the assembly?
Brian Ekins
Mod the Machine blog
Message 3 of 10
No im talking about the current view of an assembly when working on the assembly.I want to check if the assembly view is Isometric view when i open a saved assembly.
Message 4 of 10
jdkriek
There are a few ways to check the camera position and view, but it won't always be the same as hitting F6.
So personally I just automatically set it to F6 on Save.
Dim oCommandMgr As CommandManager
Set oCommandMgr = ThisApplication.CommandManager
Call oCommandMgr.ControlDefinitions.Item("AppIsometricViewCmd").Execute2(True)
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 5 of 10
Im actually supposed to perform a check wherein it checks for the assembly whether it is isometric view or not.Im not supposed to set it if it is not in isometric view i need to pop an error.Is it possible by any chance.Thanks a lot for replying.
Message 6 of 10
If I got you question right, then my solution is as follows.
In Inventor when you get a part or assembly it will be in 3Dimensional view. Not like in AuotCAD or Architecture where we can set to SW ISometric or SE Isometric etc.
In Autodesk Inventor, you will have only two options Orthographic or Perspective.
I have devoloped a code which will get view orientation of the assembly opened in Autidesk Inventor window.
The view orientation will be displayed in a msg box.
Use the following code.
Option Explicit
Sub Viewtest()
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim oview As View
Set oview = oDoc.Views.item(1)
' To get view is perspective or not.
' If view is not perspective then it is Orthographic.
MsgBox oview.Camera.Perspective
' gets view orientation in Inventor Window.
Dim orientype As ViewOrientationTypeEnum
 orientype = oview.Camera.ViewOrientationType
If orientype = 10763 Then
    MsgBox "Arbitrary View" & " & Standard Enum Value: " & "kArbitraryViewOrientation"
 Else
If orientype = 10756 Then
    MsgBox "Back View" & " & Standard Enum Value:  " & "kBackViewOrientation"
 Else
If orientype = 10757 Then
    MsgBox "Bottom View" & " & Standard Enum Value: " & "kBottomViewOrientation"
 Else
If orientype = 10765 Then
    MsgBox "Current View" & " & Standard Enum Value: " & "kCurrentViewOrientation"
 Else
If orientype = 10753 Then
    MsgBox "default View" & " & Standard Enum Value: " & "kDefaultViewOrientation"
 Else
If orientype = 10773 Then
    MsgBox "Sheet metal flat pattern backside pivot 180 degrees" & " & Standard Enum Value: " & "kFlatBacksidePivot180ViewOrientation"
 Else
 If orientype = 10772 Then
    MsgBox "Sheet metal flat pattern backside pivot left" & " & Standard Enum Value: " & "kFlatBacksidePivotLeftViewOrientation"
 Else
 If orientype = 10771 Then
    MsgBox "Sheet metal flat pattern backside pivot right" & " & Standard Enum Value: " & "kFlatBacksidePivotRightViewOrientation"
 Else
 If orientype = 10770 Then
    MsgBox "Sheet metal flat pattern backside" & " & Standard Enum Value: " & "kFlatBacksideViewOrientation"
 Else
 If orientype = 10769 Then
    MsgBox "Sheet metal flat pattern pivot 180 degrees" & " & Standard Enum Value: " & "kFlatPivot180ViewOrientation"
 Else
 If orientype = 10768 Then
    MsgBox "Sheet metal flat pattern pivot left" & " & Standard Enum Value: " & "kFlatPivotLeftViewOrientation"
 Else
 If orientype = 10767 Then
    MsgBox "Sheet metal flat pattern pivot right" & " & Standard Enum Value: " & "kFlatPivotRightViewOrientation"
 Else
 If orientype = 10764 Then
    MsgBox "Front View" & " & Standard Enum Value: " & "kFrontViewOrientation"
 Else
 If orientype = 10762 Then
    MsgBox "Isometric -- Bottom Left View" & " & Standard Enum Value: " & "kIsoBottomLeftViewOrientation"
 Else
 If orientype = 10761 Then
    MsgBox "Isometric -- Bottom Right View" & " & Standard Enum Value: " & "kIsoBottomRightViewOrientation"
 Else
 If orientype = 10760 Then
    MsgBox "Isometric -- Top Left View" & " & Standard Enum Value: " & "kIsoTopLeftViewOrientation"
 Else
 If orientype = 10759 Then
    MsgBox "Isometric -- Top Right View" & " & Standard Enum Value: " & "kIsoTopRightViewOrientation"
 Else
 If orientype = 10758 Then
    MsgBox "Left View" & " & Standard Enum Value: " & "kLeftViewOrientation"
 Else
 If orientype = 10755 Then
    MsgBox "Right View" & " & Standard Enum Value: " & "kRightViewOrientation"
 Else
  If orientype = 10766 Then
    MsgBox "Saved camera View" & " & Standard Enum Value: " & "kSavedCameraViewOrientation"
 Else
  If orientype = 10754 Then
    MsgBox "Top View" & " & Standard Enum Value: " & "kTopViewOrientation"
 Else
End Sub
 Cheers
AD.
Message 7 of 10
First msgbox give if perspective view is in perspective mode or not.
Second msgbox will give view orientation type.
Message 8 of 10
Thanks a lot for the reply got it 🙂
Message 9 of 10
Glad It worked !!!!!!!!
Please press Accept as Solution  so our friends in forums use this and some Kudos !!!!!!! Thumbs Up Smiley Happy :smileyhappy :smileyhappy
Cheers
AD
Message 10 of 10
jdkriek
ADNpati,
You can't depend on that method, it's too easy to for a user to redefine the cube without you knowing.
Also use a SWITCH statement, will be 3x faster than also those IF statements nestled together.
Jonathan D. Kriek
