drawing section view: is part cut or not
Jakob_Hamburg
Jakob_Hamburg
Hello.
I would like to know if it is possible to check if a part  in a section view (on a drawing) is cut or not.
I have an ilogic rule that automatically puts the balloons on the parts shown in the view.
But I am only interested in balloons on the parts that are cut (sectioned) in a section view (because I am showing welding symbols, so mostly the sectioned parts are only relevant).
I there a kind of property of the parts in a section view that can identify them as cut..(sth. like having a hatch)?
I would like to use that in my rule to only put balloons on the cut parts.
bradeneuropeArthur
Maybe you don't need code for that.
I you make the section-depth "0" mm than only the parts are shown/visible that are sectioned/cut.
With autoballoon you have the same result I guess!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Jakob_Hamburg
@bradeneuropeArthur
Thank you, that is a smart advice. But since we have really complex drawings with many details taken from various section views, I would like to use an ilogic selection in my rule.
Just for reference I want to add a link to another thread where it is discussed how it might be possible to get a grip on cut parts in section views. (I will look into it later since I am still working in Inventor 2021 and it requires 2022)
https://forums.autodesk.com/t5/inventor-programming-ilogic/drawing-view-hatch-hided-and-edited/td-p/...
