Message 1 of 1
Drawing automation sketchpoint into an intent
I'm working on a drawing automation, but i'm struggling on a point.
I need to transform a sketchpoint into an Intent to after used it to put drawing dimension.
I'm able to find the sketchpoint with attribut, but I don't know how to transform this sketchpoint into an Intent.
I'm using inventor 2019.
Can you help me ?
This is an extract of my general code used in an external rules :
Function FindSketchPoint(osheet As Inventor.Sheet, _ oView As Inventor.DrawingView, _ ByVal CompOccName As String, _ ByVal AttributeName As String, _ oPartType As Inventor.DocumentTypeEnum) As Inventor.GeometryIntent Dim oCol As Inventor.ObjectCollection Dim oCocc As Inventor.ComponentOccurrence Dim oPoint As Inventor.SketchPoint Dim oPointProxy As Inventor.SketchPointProxy Dim oDoc As Inventor.Document oDoc = ThisApplication.Documents.Open(oView.ReferencedDocumentDescriptor.FullDocumentName, False) If CompOccName = "" Then oCol = oDoc.AttributeManager.FindObjects("*", "*", AttributeName) oPoint = oCol.Item(1) Else Select Case oPartType Case Inventor.DocumentTypeEnum.kAssemblyDocumentObject Call processAllSubOcc1(oView, CompOccName, oCocc) oDoc = ThisApplication.Documents.Open(oCocc.ReferencedDocumentDescriptor.FullDocumentName, False) oCol = oDoc.AttributeManager.FindObjects("*", "*", AttributeName) oPoint = oCol(1) oCocc.CreateGeometryProxy(oPoint, oPointProxy) Dim Pt2d As Point2d Pt2d = oPointProxy.Geometry Logger.Debug("X : " & Pt2d.X & ", Y : "& Pt2d.Y) Case Inventor.DocumentTypeEnum.kPartDocumentObject oCol = oDoc.AttributeManager.FindObjects("*", "*", AttributeName) oPoint = oCol(1) End Select End If Dim oIntent As GeometryIntent oIntent = osheet.CreateGeometryIntent(oPointProxy) FindSketchPoint = oIntent End Function
