iLogic...Suppress all Components in an assembly
steveh3
Advisor Advisor
steveh3
Gang...
Taking a deeper dive into some iLogic.
I'm attempting to suppress all components in an assembly.
Is there a way to do this?
Then also saw that you suppress all components in a folder. I attempted this but getting an error?
Tried IV 2019 and IV2022 and get same error in both.
Thank you in advance,
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Ralf_Krieg
Hello
The simpliest way I know is to use the builtin Level of Detail. In an assembly call
ThisDoc.Document.ComponentDefinition.RepresentationsManager.LevelOfDetailRepresentations.Item(2).Activate
R. Krieg
RKW Solutions
www.rkw-solutions.com
steveh3
Thanks Kreig....
Will keep that in mind....but since LOD has been replaced by Model States in 2022....not sure that will work.
So, still looking for some insight :-).
Best,
Steve H.
Steve Hilvers
Ralf_Krieg
Hello
You can make a version for both. This suppresses only the Occurences in the main assembly. If you open a subassembly in a separate window, all of it's Occurrences will be visible.
Dim oAssDoc As AssemblyDocument = ThisDoc.Document
Dim oCompDef As AssemblyComponentDefinition=oAssDoc.ComponentDefinition
If oAssDoc.SoftwareVersionSaved.Major >= 26 Then
	Dim oModelState As ModelState
	Try
		oCompDef.ModelStates.Item("AllSuppressed").Activate
	Catch
		oModelState = oCompDef.ModelStates.Add("AllSuppressed")
	End Try
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oCompDef.Occurrences
		If oOcc.Suppressed = False Then
			oOcc.Suppress
	Next
Else
R. Krieg
RKW Solutions
