Drawing automation sketchpoint into an intent
patrice.vallet
Message 1 of 1
patrice.vallet
I'm working on a drawing automation, but i'm struggling on a point.
I need to transform a sketchpoint into an Intent to after used it to put drawing dimension.
I'm able to find the sketchpoint with attribut, but I don't know how to transform this sketchpoint into an Intent.
I'm using inventor 2019.
Can you help me ?
This is an extract of my general code used in an external rules :
Function FindSketchPoint(osheet As Inventor.Sheet, _
	oView As Inventor.DrawingView, _
	ByVal CompOccName As String, _
	ByVal AttributeName As String, _
	oPartType As Inventor.DocumentTypeEnum) As Inventor.GeometryIntent
	Dim oCol As Inventor.ObjectCollection
	Dim oCocc As Inventor.ComponentOccurrence
	Dim oPoint As Inventor.SketchPoint
	Dim oPointProxy As Inventor.SketchPointProxy
	Dim oDoc As Inventor.Document
	oDoc = ThisApplication.Documents.Open(oView.ReferencedDocumentDescriptor.FullDocumentName, False)
	If CompOccName = "" Then
		oCol = oDoc.AttributeManager.FindObjects("*", "*", AttributeName)
		oPoint = oCol.Item(1)
	Else
		Select Case oPartType
			Case Inventor.DocumentTypeEnum.kAssemblyDocumentObject
				Call processAllSubOcc1(oView, CompOccName, oCocc)
				oDoc = ThisApplication.Documents.Open(oCocc.ReferencedDocumentDescriptor.FullDocumentName, False)
				oPoint = oCol(1)
				oCocc.CreateGeometryProxy(oPoint, oPointProxy)
				Dim Pt2d As Point2d
				Pt2d = oPointProxy.Geometry
				Logger.Debug("X : " & Pt2d.X & ", Y : "& Pt2d.Y)
			Case Inventor.DocumentTypeEnum.kPartDocumentObject
				oPoint = oCol(1)
		End Select
	End If
	Dim oIntent As GeometryIntent
	oIntent = osheet.CreateGeometryIntent(oPointProxy)
	FindSketchPoint = oIntent
End Function
Replies (0)
