Drawinf file open from assembly and run external rule
Hello all
i have problem in the following code, my idea is to open drawing from assembly and update all the sheets (with help of external rule), can anyone please let me know where is the problem in my code
thanks
v.sureshkumar
Dim oCurrentSheet As Sheet
' Iterate through the sheets
Dim oSheet As Sheet
FullFilename = ThisDoc.Path & "\drawings"& "\Panel_assy_LAVT.idw"
Dim oDrawDoc as DrawingDocument = ThisApplication.Documents.Open(Fullfilename)
oDrawDoc.Activate
For Each oSheet In ThisDoc.Document.Sheets
oCurrentSheet = ThisDoc.Document.ActiveSheet
oSheet.Activate
iLogicVb.RunExternalRule("Auto_dim_arrangement")
iLogicVb.RunExternalRule("Update_all_sheet")
iLogicVb.RunExternalRule("Drawing_view_scale")
iLogicVb.UpdateWhenDone = True
oSheet.Update
Next
iLogicVb.RunExternalRule("Zoom_fit_drawing")
'return to original sheet
oCurrentSheet.Activate
MessageBox.Show("All Drawings Updated Successfully", "Panel Selection")
MechMachineMan
You need to revisit the logical flow of your programming. You had a lot of things out of place.
And your issue was grabbing a new variable instead of using a document that you have already saved.
Dim oSheet As Sheet
oDrawDoc.Activate
oCurrentSheet = oDrawDoc.ActiveSheet
For Each oSheet In oDrawDoc.Sheets
oSheet.Activate iLogicVb.RunExternalRule("Auto_dim_arrangement") iLogicVb.RunExternalRule("Update_all_sheet") iLogicVb.RunExternalRule("Drawing_view_scale") iLogicVb.RunExternalRule("Zoom_fit_drawing") iLogicVb.UpdateWhenDone = True oSheet.Update Next
'return to original sheet oCurrentSheet.Activate MessageBox.Show("All Drawings Updated Successfully", "Panel Selection")
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Dear Justin Konecsni
Good day
thanks for your reply, since i am new to ilogic and API, i don't  know how to re arrange my code, can you please advice how to re arrange or write code
v.sureshkumar
MechMachineMan
If you would have compared the 2 blocks of code, you would see the code I posted already was a revised version.............................
Justin K
