Document sub type in addin
trying to check whether a part is a sheet metal part in an inventor addin using this if statement
msbox(oDoc.SubType)
If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
msgbox("Sheet metal part")
I'm 100% certain oDoc is a sheet metal document, I've even tested the exact same code in VBA and I can see the SubType as sheet metal GUID to confirm this.
However, in my addin, the first message box in returns this string:
{41769AA9-4296-5CD8-C0D5-68AF8E5E79E2}
and if i try a different sheet metal part I will get another totally random number Smiley Frustrated
HELP !!!
bradeneuropeArthur
If I am correct there is also a documentsubtype
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
I mean there is a document subtype also for part documents. Make sure that your odoc is defined as part document.
Hope this helps.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Like below:
' Set a reference to the sheet metal document.
' This assumes a part document is active.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
' Make sure the document is a sheet metal document.
If oPartDoc.SubType "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
MsgBox "A sheet metal document must be open."
Exit Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Thank you this solved the problem.
Final code
If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
      Dim oPartDoc As PartDocument = g_inventorApplication.ActiveEditDocument
      If oPartDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
            Msgbox("Is a sheet metal part")
