Document Save iLogic Crashes Inventor
DonStauffer99
DonStauffer99
I have a rule that does some updating, and I'd like to save the part files and unload some of them when done. But if I do any kind of saving after the updating, then Inventor crashes - when the rule ends. The Document.Save method executes, and so does everything else through the end of the rule. Then Inventor crashes and sends a dump to Autodesk.
Is this a known problem?  Is there a workaround?
MechMachineMan
Haven't heard of it happening "just because" before.
It's possible that you have your ThisApplication.SilentOperation flag set to false, so it's actually throwing up a dialog that you can't see or you have a corrupt file of sorts.
Post your code so we can take a look. Also post the file it's happening in if you can.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
DonStauffer99
The code is object-oriented, so I'd be posting parts of several classes, or else 70 pages of code.
I have been able to refine my understanding of what's happening some. First off, I had to use Save2(False) and then Close(True). Anything else crashed.
Second, I could NOT save the form the rule was in. That also crashed. The crashes occurred not when the saves were being run, but when the rule finished. They were an "unhandled exception" error, but because of where they occurred I couldn't catch them in a try block.
Finally, my class destructor (in the one class I have one) is not running reliably. I tried putting the Close in the destructor, because the class records whether the file was already open or it had to open it, so the destructor can be set up to only close it if it wasn't open before. Also my class is instance counted so it can close the file only when the last instance is destroyed. And of course, using the destructor means the part closes automatically when the object goes out of scope. But I never know if the destructor is going to fire or not.
So, basically, Inventor is full of bugs and it's taken me a day to figure out workarounds for these four. The one I'm still not satisfied with is the destructor.
The beginning portion of my Part class:
 SyntaxEditor Code Snippet
'	Part
'	Base class, in the OOP sense, for all Inventor parts. That is, it is
'	intended to supply low-level control of Inventor parts to other classes.
'	Those Inventor parts can be "derived" parts, "base" parts, or neither. This
'	class is where Inventor API access happens. Each specific Inventor part
'	class object contains an instance of the Part class which it uses to do the
'	"real" work.
Public Class Part
    Private Shared InstanceCount_ As New Dictionary(Of String, Integer)
    Private Shared WasFileOpen_ As New Dictionary(Of String, Boolean)
    Private App_ As Application
    Private Dim DisplayName_ As String
    Private Doc_ As PartDocument
    '	Constructor
    '	Loads document into memory if necessary, and saves a reference to it.
    '   Increments instance count, and, for first instance, stores whether the
    '   file was in memory already.
    Public Sub New(ByRef App As Application, ByRef DisplayName As String)
        App_ = App
        DisplayName_ = DisplayName
        '   Add to instance count
        Dim n As Integer
        With InstanceCount_
            .TryGetValue(DisplayName_, n)
            .Item(DisplayName_) = n + 1
        End With
        '	Get reference to part document if it's in memory already
        For Each d As Document In App_.Documents
            If d.DisplayName() = DisplayName_ Then
                Doc_ = d
                If n = 0 Then
                    WasFileOpen_.Item(DisplayName_) = True
                Exit Sub
        Next
        '	Document was not in memory. Load it.
        If n = 0 Then WasFileOpen_.Item(DisplayName_) = False
        Doc_ = OpenDoc()
    End Sub '	New
    '	Destructor
    '   Decrements the instance count and, for last instance, saves the file,
    '   then closes it if it had to be opened on construction of first instance.
    Protected Overrides Sub Finalize()
        '   Reduce instance count
        Dim n As Integer
        With InstanceCount_
            If n > 0 Then .Item(DisplayName_) = n - 1
        End With
        If n > 1 Then Exit Sub
        If Doc_ Is Nothing Then Exit Sub
        '   Save document if possible
        ' Save()
        '   Close document if it had to be opened and this is the last instance
        Dim WasFileOpen As Boolean
        WasFileOpen_.TryGetValue(DisplayName_, WasFileOpen)
        If Not WasFileOpen Then Close()
    End Sub '	Finalize
    '	OpenFile
    '	Attempts to open the part file, suppressing errors.
    '	Returns Document reference, or Nothing for failure.
    Private Function OpenFile(ByRef dirSpec As String) As Document
	Dim filespec As String = dirSpec & "\" & DisplayName_ & ".ipt"
	App_.SilentOperation = True
	Try
    	OpenFile = App_.Documents.Open(filespec)
	Catch ex As Exception
		OpenFile = Nothing
	End Try
	App_.SilentOperation = False
    End Function	'	OpenFile
    '	OpenDoc
    '	Finds and opens the document file.
    Private Function OpenDoc() As Document
        '	Get Workspace path
        Dim dpm As DesignProjectManager
	Dim dp As DesignProject
	dpm = App_.DesignProjectManager
	dp = dpm.ActiveDesignProject
	'	Try to open document there
	Dim doc As Document = OpenFile(dp.WorkspacePath)
	If Not doc Is Nothing Then
		OpenDoc = doc
		Exit Function
	'	Try to open file in each, testing for not found error
	For Each p As ProjectPath In dp.WorkgroupPaths
		doc = OpenFile(p.Path())
			OpenDoc = doc
			Exit Function
	Next
	OpenDoc = Nothing
    End Function    '	OpenDoc
    '	Save
    '	Saves the file to disk.
    Public Sub Save()
        Doc_.Save2(False)
    End Sub '	Save
    Public Sub Close()
        Doc_.Close(True)
    End Sub
DonStauffer99
My workaround for the destructor unreliability:
    '   CloseIfYouOpened
    '   Closes the document if the first instance of this class for that
    '   document opened it.
    Public Sub CloseIfYouOpened()
    End Sub    '   CloseIfYouOpened
