Document (part or sub-assembly) highlight color is different from default blue c
RoyWickrama_RWEI
Advisor Advisor
Message 1 of 14
RoyWickrama_RWEI
I have part of my rule that I select documents from within the assembly.
The rule is fine (i.e., the selected document gets highlighted at the time of selecting). But the color is different from default blue.
Could someone help to fix this issue! Thanks.
Public Class RWEI_0023A
Sub main()
Dim iL_NO As String = "0025A"
Dim iL_Name As String = "Highlighted Multiple Selections"
Dim iL_FFN As String = "Rule " & iL_NO & ": " & iL_Name
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
	Dim oLFN_Pos As Long
	Dim oFFN As String	'Full file name (with extension)
	Dim oLFN As String	'Local file name (with extension)
Dim oSelectionOptions As New ArrayList
Dim oComp As String  = "Component"
Dim oPart As String = "Part"
Dim oCancell As String = "Cancel"
oSelectionOptions.Add(oComp)
oSelectionOptions.Add(oPart)
oSelectionOptions.Add(oCancell)
Dim oSelectedSet As Inventor.HighlightSet
oSelectedSet = oDoc.CreateHighlightSet
oSelectedSet.Clear
Dim oEntities As ObjectCollection
oEntities = ThisApplication.TransientObjects.CreateObjectCollection
Dim oOccurrence As ComponentOccurrence
oSelection = InputListBox("SELECT", oSelectionOptions, oSelectionOptions(0), Title := iL_NO & ": COMPONENT SELECTION", ListName := iL_NO & ": Selection List")
If oSelection = oCancell Then Exit Sub
While True
	If oSelection = oComp Then
		oEntity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, iL_NO & ": Select Component:")
	Else If oSelection = oPart Then
		oEntity = ThisApplication.CommandManager.Pick(kAssemblyLeafOccurrenceFilter, iL_NO & ": Select Part:")
	If IsNothing(oEntity) Then Exit While
	oSelectedSet.AddItem(oEntity)
	oEntities.Add(oEntity)
End While
oSelectedSet.Clear
i = 1
For Each oEntity In oEntities
'	oDoc_Entity = oEntity.Definition.Document
'	oFFN = oDoc_Entity.FullFileName
'	oLFN_Return = oName_Doc_Local(oFFN, oLFN_Pos, oLFN)
'	MessageBox.Show("Name - Occurrence: " & oEntity.Name _
'	& vbLf & "Name - LFN: " & oLFN_Return _
'	& vbLf & "Name - FFN: " & oDoc_Entity.FullFileName, iL_FFN)
''	i += 1
Next
End Sub
Function oName_Doc_Local(oFFN As String, oLFN_Pos As Double, oLFN As String)
		oLFN_Pos = InStrRev(oFFN, "\", -1)
		oLFN = Mid(oFFN, oLFN_Pos + 1, Len(oFFN) - oLFN_Pos)
		Return oLFN
End Function
End Class
Replies (13)
Message 2 of 14
bradeneuropeArthur
Maybe I don't understand, but I don't see any code that changes the color!!
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 14
bradeneuropeArthur
I understand now...
I will see.....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 14
RoyWickrama_RWEI
Thanks for taking time to take a look at this.
Message 5 of 14
bradeneuropeArthur
I am still struggling with the color too.
Think that it also could be a api bug.
But I am not sure.
A tried to change the color to ie red but also not working.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI ,
Hoping that below settings in Application options may be helpful.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 7 of 14
RoyWickrama_RWEI
Thanks for the reply. It opened me some where I totally neglected.
But, it not not yielding the results I expect. But, good to explore. Thanks.
Message 8 of 14
bradeneuropeArthur
Still think there is an API bug here.
I tried to change the color by .SetColor(255,0,0), but this is not working.
So to my opinion maybe a bug!!!!
Maybe Autodesk can confirm this?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 14
RoyWickrama_RWEI
You are right.
For now, it is OK because it is highlighted any way (@ a weird color).
I have a humble request. In my other post, I need to have the bom structure including the items made referenced from within assembly. Do you think, could you shed some light on this! Thanks.
https://forums.autodesk.com/t5/inventor-customization/bom-structure-assigned-assy-level-not-captured...
Message 10 of 14
bradeneuropeArthur
I have tried this with no result...
Dim r As Byte = 250
Dim g As Byte = 0
Dim b As Byte = 0
oSelectedSet.Color.SetColor (r,g,b)
MsgBox (oSelectedSet.Color.Red & "-" & oSelectedSet.Color.Green & "-" & oSelectedSet.Color.Blue)
Result is always 240 0 0
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI ,
Try below code to change the color of highlighted sets. @bradeneuropeArthur is provided valuable hint to change the color of selection.
Sub main()
	oSelectedSet.Clear
	Dim r As Byte = 0
	Dim g As Byte = 0
	Dim b As Byte = 250
 	Dim oColor As Color
    oColor = ThisApplication.TransientObjects.CreateColor(r,g,b)
	oSelectedSet.Color = oColor
	While True
	End While
	oSelectedSet.Clear
	i = 1
	''	i += 1
	Next
End Sub
		Return oLFN
End Function
End Class
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 12 of 14
RoyWickrama_RWEI
Thanks a lot Chandra.Shekar.
It is doing well.
At this moment, I thank @bradeneurope|Arthur as well - was so much helpful.
Message 13 of 14
bradeneuropeArthur
@chandra.shekar.g
That did the trick:
	Dim r As Byte = 0
	Dim g As Byte = 0
	Dim b As Byte = 250
 	Dim oColor As Color
Well done Smiley Wink
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@bradeneuropeArthur
@bradeneuropeArthur wrote:
@chandra.shekar.g
That did the trick:
	Dim r As Byte = 0
	Dim g As Byte = 0
	Dim b As Byte = 250
 	Dim oColor As Color
Yes, this is what needed to assign color to selectset.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
