Do after user parameter change
mk92
mk92
is there any method to check if a user parameter is changed?
Like:
If AnyUserParameter changed then
End If
Or:
If UserParameter X changed then
End If
LukeDavenport
Are you using iLogic?
Several ways of getting code to run if a user parameter changes:
1) Set event trigger for Any Model Parameter Change, and reference the User parameter in a model parameter. This is a 'brute force' method and will obviously run every time any model param changes.
2) If the user parameter is explicitly referred to in the iLogic rule (and it therefore appears in blue text) then as long as the Options tab in the iLogic rule 'Don't run Automatically' is NOT ticked the rule will run whenever that specific parameter changes.
3) If you want a different method then you can create a 'memory' user parameter, e.g. Length_Memory and then use it as follows:
' Check if Length parameter has changed
If Not Length = Length_Memory Then
      ' Do Something
End If
' Set memory parameter again
Length_Memory = Length
Does this help?
Luke
mk92
Yes i work with iLogic.
The third part works fine.
      ' Do Something
End If
But i have 4 parameters to check and any of it start the same if-loop. Is there a way to do that without typing it 4 times?
Like:
If Not Length_* (* stands for any parameter with nearly the same name like Length_1, Length_2....)
    'Do something
LukeDavenport
Well this might be the simplest way of doing it.
If Not Length = LengthMemory OrElse Not Width = WidthMemory OrElse Not
Height = HeightMemory
End If
Other than that you could use a smarter method by:
1) Create a memory parameter for each one: i.e. LengthMemory etc
2) Tick the important parameters as 'Key'
Use this rule (I haven't tested this properly - use at your own risk)...
' Define stuffDim oKeyParamColl As ObjectCollection =
ThisApplication.TransientObjects.CreateObjectCollection Dim oParam As
Inventor.ParameterDim Run As Boolean = False
' Run through all key parameters, checking value against matching
'memory' parameterFor Each oParam In
ThisApplication.ActiveEditDocument.ComponentDefinition.Parameters
If oParam.IsKey Then
' Add the key parameter to the object collection
oKeyParamColl.Add(oParam.Name)
Try
If Not Parameter(oParam.Name) = Parameter(oParam.Name & "Memory") Then
If Not Run Then
MsgBox("RUNNING MAIN CODE.......",,"")
' Put your main code here.................
Run = True
End If
End If
Catch
MsgBox("You need to create a parameter called " &
oParam.Name & "Memory - exiting iLogic rule...",,"")
Exit For
End Try
End IfNext
' Reset all 'memory' parameters to current correct values...For Each
KeyParam As String In oKeyParamColl
Parameter(KeyParam & "Memory") = Parameter(KeyParam)Next
InventorVb.DocumentUpdate()
mk92
I used this:
      Mode = 1
End If
Width = WidthMemory
But when i change one of the parameters nothing happens. Is there a mistake? I use this method because i want to keep it as simple as possible.
mk92
And i got an other problem. With:
Parameter.Quiet = True
Pos_1 = Parameter("Position_1")
If Not Pos_1 = Pos_Memory_1 Then
   Mode = 1
End If
Pos_Memory_1 = Pos_1
I need the first two lines because the parameter is not existing all the time. But i need to check it for changes. Then the the parameter Mode =1 and an If Loop begins again! The If Loop updates the Model so you can see the position change!
LukeDavenport
MK92, you have got the statements at the end the wrong way round. It should read:
LengthMemory = Length
WidthMemory = Width
HeightMemory = Height
And for your second question - you should start a new post for this.
