Convert IDW to DWF
Convert IDW to DWF
amitnkukanur
Convert IDW to DWF
amitnkukanur
I am doing a project which is about converting IDW files to DWF.
I problem i am facing is Inventor is getting crashed every non and then.
This is the below code which i am using to convert to DWF
Document oDoc = InvApp.Documents.Open(filenamepath, false);
DrawingDocument oDrwDoc = (DrawingDocument)oDoc;
DataIO aa;
oDrwDoc.Update(); // Here i am updating the drawing document
aa = oDrwDoc.Sheets[1].DataIO;
aa.WriteDataToFile("DWF", "C:\temp\test.dwf"); //Crash on this line
oDrwDoc.Close(true);
oDoc.Close(true);
If there is any other way which helps to do this, that would be helpful.
Cheers,
Amit
Senior Software Engineer
Hi ,
This maybe useful for you .Sorry i have done it in VBA.Hope it helps
Public Sub saveAsDWF()
  Dim oDrawDoc As DrawingDocument
  Set oDrawDoc = ThisApplication.ActiveDocument
  Call oDrawDoc.SaveAs(""C:\temp\test.dwf", True)
  oDrawDoc.Close (True)
End Sub
amitnkukanur
Hi Prakash,
Thanks for reply. I solved  the issue with some round work using Cross language Support Feature in .NET
PublicSub writeDWF()
Try
Dim oAApp AsApprenticeServerComponent = NewApprenticeServerComponent()
Dim oDoc AsApprenticeServerDrawingDocument = oAApp.Open(FileName)
Dim oSheet AsSheet = oDoc.Sheets(1)
Dim oDataIO AsDataIO = oSheet.DataIO
'oDataIO.WriteDataToFile("DWF", "c:\temp\1101-22247.dwf")
FileName = FileName.Replace(".idw", ".dwf")
oDataIO.WriteDataToFile("DWF", FileName)
oDoc.Close()
oAApp.Close()
Catch ex AsSystemException
EndTry
EndSub
This above code is working fine in VB.net, if i convert same to C#, its giving some problem.
Hence I created a DLL with COM Visibility in VB.NET and included the DLL in C#.
Then i called WriteDWF method by passing filepath it got converted fine.
Thanks for reply.
rgds
Amit
