DLL Recompilation With Inventor Open
DonStauffer99
DonStauffer99
I have several class library DLLs for Inventor. To test them after I make changes, I open Inventor and invoke methods via an iLogic rule. If there are errors, I change the source code and recompile, but if I don't first close Inventor, Visual Studio gives this error:
Could not copy "obj\Debug\Part Classes.dll" to "..\..\..\DLL\Part Classes.dll". Beginning retry 1 in 1000ms. The process cannot access the file '..\..\..\DLL\Part Classes.dll' because it is being used by another process. The file is locked by: "Autodesk® Inventor® 2018 (7344)"    Part Classes
This error doesn't appear if I haven't used the DLL yet in this Inventor session.
I pretty much understand what this means, but I'm wondering if there's a way around it without closing Inventor, since loading it up again every time I want to test a change is time-consuming and tedious.
Does anyone know of a way to get around this?
bradeneuropeArthur
You only can start inventor with the debug of the application. you cannot do this with the inventor session open because also the dll files are loaded then in inventor.
I use the following method.
in the debug you can also start inventor.exe with the debug of the app.
it will also close again after debug and start again with debug.
you understand what I mean?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
DonStauffer99
It sounds like it may be less tedious but not much faster.
frederic.vandenplas
Hi, i use an standalon exe for testing purposes, when finished i copy the code in my addin.
Then you can use the suggestion to start inventor from vb.net for debugging if something is wrong to run that function.
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
bradeneuropeArthur
I use VBA to test and after the test I put it in the vb.net add in. (when possible)
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
