Distances between solid bodies
orhan.alihanov
orhan.alihanov
I'm trying to find the minimum distance between a solid body and a plane.
I have an idea to select any vertex of the body and find the distance to the plane:
For Each solid In partDoc.ComponentDefinition.SurfaceBodies
		g = Measure.MinimumDistance(solid.Vertices(1), "YZ Plane")
Next
Dev_rim
Hi there,
This is the code given distance between "YZ Plane" and '1' indexed vertex of each solid.
    Dim Distance as Double
    Distance = partDoc.ComponentDefinition.WorkPlanes("YZ Plane").Plane.DistanceTo(solid.Vertices(1).Point)
Next
If you want to get all vertices on a Solid and find the closest one:
    Dim minimumDistance as Double
    Dim vertexCounter as Int
    vertexCounter = 0
    Dim vertex as Vertex
    For Each vertex in solid.Vertices
        Dim distance as Double
        If vertexCounter = 0 Then
            minimumDistance = = partDoc.ComponentDefinition.WorkPlanes("YZ Plane").Plane.DistanceTo(vertex.Point)
        Else
            distance = partDoc.ComponentDefinition.WorkPlanes("YZ Plane").Plane.DistanceTo(vertex.Point)
            If distance < minimumDistance Then
                minimumDistance = distance
    vertexCounter = vertexCounter+1
    Next
    vertexCounter =0
Next
Best Regards
Devrim
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
orhan.alihanov
Thank you very much, helped a lot!
