"Highlight" specific solid bodies in a part File
C_Haines_ENG
Message 1 of 9
C_Haines_ENG
I can almost garuentee this isnt possible, but im essentially automating our descriptions but for that you need to enter what kind of panel youre working with. Essentially, when you highlight over a solidbody you get this look:
Is it possible to replicate this with ilogic?
My program will cycle through each solid body, and ask for the panel name.
Replies (8)
Message 2 of 9
JelteDeJong
You can try something like this:
Dim oTr As TransientObjects = ThisApplication.TransientObjects
Dim doc As AssemblyDocument = ThisDoc.Document
For Each occ As ComponentOccurrence In doc.ComponentDefinition.Occurrences
	Dim topFace As HighlightSet = doc.HighlightSets.Add()
	topFace.Color = oTr.CreateColor(0, 255, 0, 0.1)
	topFace.Clear()
	topFace.AddItem(occ)
	Dim newName = InputBox("Plz give a new name", "Name PLZ", occ._DisplayName)
	iProperties.Value("Project", "Description") = newName
	topFace.Remove(occ)
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 9
C_Haines_ENG
I need it to work on part files with solid bodies, yours seems to only work with assembly documents.
Message 4 of 9
J-Camper
@C_Haines_ENG,
Here it is for Solid bodies in a Part Environment:
Dim pDoc As PartDocument = TryCast(ThisApplication.ActiveDocument, PartDocument)
If IsNothing(pDoc) Then Logger.Debug("Active Document is not: " & CType(pDoc.Type, ObjectTypeEnum).ToString)
Dim selectThis As HighlightSet = pDoc.CreateHighlightSet
For Each oSolid As SurfaceBody In pDoc.ComponentDefinition.SurfaceBodies
	selectThis.AddItem(oSolid)
	MessageBox.Show("Solid Selected", "Pause for Action")
	selectThis.Clear
Next
Let me know if you have any questions
Message 5 of 9
JelteDeJong
oke try this:
Dim doc As PartDocument = ThisDoc.Document
For Each body As SurfaceBody In doc.ComponentDefinition.SurfaceBodies
	topFace.Clear()
	topFace.AddItem(body)
	Dim newName = InputBox("Plz give a new name", "Name PLZ", body.Name)
	body.Name = newName
	topFace.Remove(body)
Next
Jelte de Jong
Message 6 of 9
C_Haines_ENG
**** you cant see the highlighted panel through objects, is there a hide others command?
Message 7 of 9
JelteDeJong
Give it a try like this:
    Dim color As Color = oTr.CreateColor(0, 255, 0, 1)
    Dim highlightSet As HighlightSet = doc.HighlightSets.Add()
    highlightSet.Color = color
    For Each edge As Edge In body.Edges
        highlightSet.AddItem(Edge)
    Next
    body.Name = InputBox("Plz give a new name", "Name PLZ", body.Name)
    highlightSet.Remove(body)
Next
Jelte de Jong
Message 8 of 9
J-Camper
@C_Haines_ENG,
Here is an example where I hide all other bodies.  Not sure if you still need them to be highlighted at that point, but I left it in:
Sub Main
	Dim AllBodies As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	For Each sb As SurfaceBody In pDoc.ComponentDefinition.SurfaceBodies
		AllBodies.Add(sb)
	Next
		AllBodies.RemoveByObject(oSolid)
		Call HideAll(AllBodies, False)
		selectThis.Clear
		Call HideAll(AllBodies, True)
		AllBodies.Add(oSolid)
	Next
End Sub
Sub HideAll(BodyCol As ObjectCollection, Visibility As Boolean)
	For Each sb As SurfaceBody In BodyCol
		sb.Visible = Visibility
	Next
End Sub
The only way to use the UI "HideOthers" command is through ControlDefinitions, which I'm not a fan of, but it could look like this:
Sub Main
	Dim selSet As SelectSet = pDoc.SelectSet
	Dim HideOthers As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("HideOtherBodiesCtxCmd")
	Dim ShowAll As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("ShowAllBodiesCtxCmd")
		selSet.Select(oSolid)
		HideOthers.Execute
		selectThis.Clear
		selSet.Remove(oSolid)
	Next
	ShowAll.Execute
End Sub
Message 9 of 9
C_Haines_ENG
This works fantastic! Thank you!
