VBA Open Files from Vault, Not Local
rcolon9E4ZX
rcolon9E4ZX
Hello.
I have a list of part numbers in Excel. I want to loop through and open each IDW from the vault that matches the part number, exporting as PDF to a target folder for our machining queue. I would like to input only the part number, not the whole path. We format our filenames as Path + Part Number + Description.
I want to do this with VBA if I can, not VB.NET, as I have a ton of code already in VBA format as Inventor macros running from Inventor. I already have the code for grabbing the names from Excel and the PDF export, I just need the Vault communications. We only have one Vault Server, Inventor Vault, and project file.
I have done a great deal of searching to no avail. I have yet to find a simple Open from Vault method with the active vault and specified file. Do I need to add a certain reference or install an SDK? Several VB.NET examples use Autodesk.Connectivity.WebServices for example, but I have not found a way to reference in VBA. I suspect several others are looking for a similar solution based on my searches.
Any help with this would be greatly appreciated. Many thanks.
Rafael
INV2022.3 Professional
WIN10 Pro 21H2
theo.bot
API access to Vault is only available for Vault workgroup / Vault professional, So do you have this running? If so, you might not need to code anything. There is default functionality to create PDF documents in Vault based on document state changes or by a manual job assignment. (https://www.autodesk.com/autodesk-university/class/Automatic-PDF-Creation-Drawings-Vault-Professiona...)
Did you also checked the API reference in the documentation: https://help.autodesk.com/view/VAULT/2023/ENU/?guid=GUID-5FE06775-9EF2-4FFA-9945-AB6D853966FD
rcolon9E4ZX
@theo.bot ,
I am using Vault Basic. I wrote the program in VB.NET to open from vault. Only now, I am having trouble with distributing. I can publish to exe from Visual Studio 2019, but security blocks the install. I would rather implement as part of my existing VBA utility.
FYI, I started with Visual Studio 2022 and had to uninstall and install 2019 because I could not install the Inventor 2022 SDK until doing so.
Imports Excel = Microsoft.Office.Interop.Excel
Public Class Form1
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        Me.ListBox_Parts.Items.Clear()
        btnBrowse.Select()
    End Sub
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles btnOpenDrawings.Click
        If ListBox_Parts.Items.Count < 1 Then
            MsgBox("No parts selected")
            Exit Sub
        Dim x As clsVault
        x = New clsVault
        Dim parts(49) As String, i As Long
        For i = 0 To Me.ListBox_Parts.Items.Count - 1
            parts(i) = Me.ListBox_Parts.Items(i)
        Next i
        x.GetFilesFromList(parts)
        End
    End Sub
    Private Sub btnBrowse_Click(sender As Object, e As EventArgs) Handles btnBrowse.Click
        Dim appXL As Excel.Application
        Dim wbXl As Excel.Workbook
        Dim shXL As Excel.Worksheet
        Dim raXL As Excel.Range
        ' Add a new workbook.
        Dim strFile As String = vbNullString
        Dim openFile As New OpenFileDialog
        openFile.Filter = "Excel files (*.xlsx)|*.xlsx"
        openFile.ShowDialog()
        If openFile.FileNames().Length = 1 Then
            strFile = openFile.FileName
        Else
            'MsgBox("User Cancelled")
            Exit Sub
        ' Start Excel and get Application object.
        appXL = CreateObject("Excel.Application")
        appXL.Visible = False
        wbXl = appXL.Workbooks.Open(strFile,, True)
        shXL = wbXl.ActiveSheet
        ' Create an array to set multiple values at once.
        'Me.ListBox_Parts.Items.Clear()
        Dim lRow As Long = 0
        Dim strText As String = vbNullString
        Dim AddedAtLeastOne As Boolean = False
        With shXL
            For lRow = 0 To 49
                strText = vbNullString
                strText = .Cells(lRow + 1, 1).Value
                parts(lRow) = strText
                If strText IsNot vbNullString Then
                    'Check for duplicate
                    If Me.ListBox_Parts.Items.Count = 0 Then
                        Me.ListBox_Parts.Items.Add(strText)
                        AddedAtLeastOne = True
                    Else
                        Dim j As Integer = 0
                        Dim match As Boolean = False
                        For j = 0 To Me.ListBox_Parts.Items.Count - 1
                            If strText = Me.ListBox_Parts.Items(j).ToString Then
                                match = True
                                Exit For
                        Next j
                        If match = False Then
            Next
        End With
        Dim numParts As Long
        numParts = Me.ListBox_Parts.Items.Count
        'Dim files(49) As String
        ' Make sure Excel is visible and give the user control
        ' of Excel's lifetime.
        appXL.Visible = True
        appXL.UserControl = True
        ' Release object references.
        raXL = Nothing
        shXL = Nothing
        wbXl = Nothing
        appXL.Quit()
        appXL = Nothing
        If AddedAtLeastOne = True Then
            btnOpenDrawings.Select()
        Else
            MsgBox("No unique parts found in Excel list")
    End Sub
    Private Sub btnClear_Click(sender As Object, e As EventArgs) Handles btnClear.Click
    End Sub
    Private Sub btnRemove_Click(sender As Object, e As EventArgs) Handles btnRemove.Click
        Try
            Me.ListBox_Parts.Items.RemoveAt(Me.ListBox_Parts.SelectedIndex)
        Catch ex As Exception
            MsgBox("None selected")
        End Try
    End Sub
    Private Sub btnAdd_Click(sender As Object, e As EventArgs) Handles btnAdd.Click
        Dim myString As String = vbNullString
        myString = Me.TextBox_Add.Text
        If myString = vbNullString Then
            'Nothing to add
            Exit Sub
        'Check if already added
        Dim i As Integer = 0
            If myString = Me.ListBox_Parts.Items(i) Then
                MsgBox("Already in list")
                Exit Sub
        Next i
        'Add to list
        Me.ListBox_Parts.Items.Add(myString)
        Me.TextBox_Add.Text = vbNullString
    End Sub
End Class
Imports Inventor
Imports Microsoft.Office.Interop.Excel
Imports Autodesk.DataManagement.Client.Framework.Vault
Imports Autodesk.Connectivity.WebServicesTools
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports ACW = Autodesk.Connectivity.WebServices
Imports System.Collections
Imports System.Linq
Imports System.Windows.Forms
Public Class clsVault
    Dim FileIters As System.Collections.Generic.ICollection(Of VDF.Vault.Currency.Entities.FileIteration)
    Public Shared myString As String
    Public Sub GetFilesFromList(parts() As String)
        'LOG IN
        Dim results1 As Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("Vault", "ABTEX_Vault", "rcolon", "", VDF.Vault.Currency.Connections.AuthenticationFlags.Standard, Nothing)
        If Not results1.Success Then
            MsgBox("Error1")
        Dim connection As VDF.Vault.Currency.Connections.Connection = Nothing
        connection = results1.Connection
        'GET INVENTOR
        Dim m_inventorApp As Inventor.Application = Nothing
        Try
            m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
            MsgBox("Error2")
        End Try
        Try
            If m_inventorApp Is Nothing Then
                MsgBox("Error3")
                Return
        Catch
        End Try
        m_inventorApp.Visible = True
        Dim filePropDefs As ACW.PropDef() =
        connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE")
        Dim fileNamePropDef As ACW.PropDef =
        filePropDefs.[Single](Function(n) n.SysName = "ClientFileName")
        Dim filepaths As New List(Of String)()
        Dim files As New List(Of ACW.File)()
        Dim part As String = vbNullString
        For Each part In parts
            If part IsNot Nothing Then
                ' SrchOper 1 => contains
                ' SrchOper 3 => equals
                Dim fileNameToFind As New ACW.SrchCond() With {
                    .PropDefId = fileNamePropDef.Id,
                    .PropTyp = ACW.PropertySearchType.SingleProperty,
                    .SrchOper = 1,
                    .SrchRule = ACW.SearchRuleType.Must,
                    .SrchTxt = part '"C0011A05P008 Guard Rear Bracket" 'part
                Dim bookmark As String = String.Empty
                Dim status As ACW.SrchStatus = Nothing
                Dim totalResults As New List(Of ACW.File)()
                Dim rslt As ACW.File
                While status Is Nothing OrElse totalResults.Count < status.TotalHits
                    Dim results As ACW.File() =
                        connection.WebServiceManager.DocumentService.FindFilesBySearchConditions(New ACW.SrchCond() {fileNameToFind}, Nothing, Nothing, False, True, bookmark, status)
                    If results IsNot Nothing Then
                        'File(s) found
                        totalResults.AddRange(results)
                        For Each rslt In totalResults
                            If Microsoft.VisualBasic.Right(rslt.Name, 4) = ".idw" Then
                                'Add to list of file paths
                                files.Add(rslt)
                                Dim results2 As ACW.FilePath() = connection.WebServiceManager.DocumentService.FindFilePathsByNameAndChecksum(rslt.Name, rslt.Cksum)
                                If results2 IsNot Nothing Then
                                    filepaths.Add(results2(0).Path)
                        Next rslt
                    Else
                        Exit While
                End While
                'connection.WebServiceManager.DocumentService.FindFilePathsByNameAndChecksum()
                ' total results now has the results
                'totalResults.Item(2).FolderId
        Next part
        Dim DocService As ACW.DocumentService
        DocService = connection.WebServiceManager.DocumentService
        Dim file As ACW.File
        'get settings
        Dim oSettings As VDF.Vault.Settings.AcquireFilesSettings = New VDF.Vault.Settings.AcquireFilesSettings(connection)
        oSettings.DefaultAcquisitionOption = VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Download 'Or VDF.Vault.Settings.AcquireFilesSettings.AcquisitionOption.Checkout
        For Each file In files
            Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = Nothing
            oFileIteration = New VDF.Vault.Currency.Entities.FileIteration(connection, file)
            Try
                If oFileIteration IsNot Nothing Then
                    oSettings.AddEntityToAcquire(oFileIteration)
                    myString = "NE"
                Return
            Finally
            End Try
        Next
        Try
            connection.FileManager.AcquireFiles(oSettings)
            Return
        End Try
        VDF.Vault.Library.ConnectionManager.LogOut(connection)
        Dim filepath As String = vbNullString
        For Each filepath In filepaths
            filepath = filepath.Replace("$/", "C:\Vault_Workspace\ABTEX_Vault\")
            filepath = filepath.Replace("/", "\")
            m_inventorApp.Documents.Open(filepath)
        Next
        m_inventorApp = Nothing
        myString = Nothing
    End Sub
End Class
Kind regards,
Rafael
WIN 10 21H2
JelteDeJong
I think you would be better off if you changed your application to an Inventor addin. I wrote a tutorial about writing an addin. ("Creating an Inventor Addin" is the start but I think you will find "Adding a form to your addin" also interesting.) Then when you managed that you can start adding all other (VBa) utilities to this addin. The problem with VBa is, that it's obsolete. (Is VBA in Inventor obsolete?) Therefore you will need to convert all your code at some point anyway.
Jelte de Jong
Blog: hjalte.nl - github.com
