Display units in Tons
juanpablo.molinaKGVXV
Message 1 of 10
Hello everyone, I need to do the following, I have an equation that gives me a result in kg, but I want the final result to be in Tons, I show you in the following image.
With the values ​​enclosed I configured my equation which gives me a result that says Tons but the units are in kg.
These are my parameters so that when entering data it gives me the result of the weight.
What I need is for it to show me Tons and not kg.
Replies (9)
Message 2 of 10
arthurknoors
Hey, That sound familiar to your question on LI!
Message 3 of 10
bradeneuropeArthur
I have had contact with your via the LI forum, isnt it?
could you share one ipt with me?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 10
J-Camper
@juanpablo.molinaKGVXV,
I don't think a Ton is an available option for Parameter units.  What you could do is make a unitless parameter and do a conversion from a usable Force unit type.  Like this:
Message 5 of 10
bradeneuropeArthur
If only used in the form you don't even need parameters or properties!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 10
Yes, I'm here too, friend.
Message 7 of 10
Here it is
Message 8 of 10
Curtis_W
I think you can change the parameter to be a text parameter as shown:
Then in your rule calculate the kgs, convert to tons, round as needed, and add the units string
Message 9 of 10
Michael.Navara
It can looks obscure, but you can use syntactically valid unit "MegaGram" (Mg) which corresponds with metric tons.
Message 10 of 10
Excellent my friend, that was what I needed to do, thanks for your help.
Regards
