Dimensions of Assembly in idw Drawing
Archershome
Archershome
I was wondering if anybody would be able help with some code that will do the following:
I have a automated ilogic model that is then used within a 2D drawing, this 2D drawing then has dimensions on it referenced to the the model.
This model changes in its length the dimension associated with its length then changes but the dimension text then goes outside of the dimension boundary (does not stay central)
Is there any code that can scan the dimensions and in effect tidy them up?
Any other ideas of how else this could be done would be great.
Cheers in advance
ChrisAtherton
I use the following in a rule:
    ' Set a reference to the active drawing document
    Dim oDoc As DrawingDocument
    oDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet
    Dim oSheet As Sheet
    oSheet = oDoc.ActiveSheet
    Dim oDrawingDim As DrawingDimension
    ' Iterate over all dimensions in the drawing and
    ' center them if they are linear or angular.
    For Each oDrawingDim In oSheet.DrawingDimensions
        If TypeOf oDrawingDim Is LinearGeneralDimension Or _
           TypeOf oDrawingDim Is AngularGeneralDimension Then
            Call oDrawingDim.CenterText
        End If
    Next
Chris Atherton
IEng MIMechE BEng Hons
Design Automation Services Manager | Symetri
https://uk.linkedin.com/in/chrissoathe
Archershome
Thank you very much Smiley Happy
ChrisAtherton
No problem,
If you look at the code you'll see its similar to the sample in the API help file that comes with inventor.  This is a great resource for finding bits of code that can be used within your iLogic rules.  To use it you either need to convert it from VBA to something that you can use in iLogic or add the sample as a macro that you call via your code.
Once your happy with the solution in this forum please mark it as solved.
Chris
Chris Atherton
