Symbol Insertion point
Ktomberlin
Ktomberlin
Just trying to add an existing symbol to a drawing sheet.  I know i'm not formating the point correctly and i get a position error.  How can i get the point location of two intersecting lines in my border to hard code the location?
Error:
Error on Line 18 : Argument not specified for parameter 'Position' of 'Public Function Add(SketchedSymbolDefinition As Object, Position As Inventor.Point2d, [Rotation As Double = 0.0], [Scale As Double = 1.0], [PromptStrings As Object]) As Inventor.SketchedSymbol'.
Error on Line 18 : End of statement expected.
DimoApp As Inventor.Application=ThisApplication
DimthisIDW As DrawingDocument=oApp.ActiveDocument
oSheet=thisIDW.ActiveSheet
DimoSymDef As SketchedSymbolDefinition
oSymDef=thisIDW.SketchedSymbolDefinitions.Item("APPROVAL STAMP")myPoint=ThisApplication.TransientGeometry.CreatePoint2d(1, 6)
oSheet.SketchedSymbols.Add(oSymDef) ,myPoint
jdkriek
Here you go, little clean up, and it works now 😉
Should be oSheet.SketchedSymbols.Add(oSymDef, myPoint)
Dim oApp As Inventor.Application = ThisApplication
Dim thisIDW As DrawingDocument = oApp.ActiveDocument
Dim oSheet As Sheet = thisIDW.ActiveSheet
Dim oSymDef As SketchedSymbolDefinition = thisIDW.SketchedSymbolDefinitions.Item("APPROVAL STAMP")
Dim myPoint As Point2d = oApp.TransientGeometry.CreatePoint2d(1, 6)
Dim oSymbol As SketchedSymbol = oSheet.SketchedSymbols.Add(oSymDef, myPoint)
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Ktomberlin
Thank you.  Silly coding error now that i see it.
jdkriek
You're welcome 😉
Jonathan D. Kriek
