devoloper.msi templates*zip files
Hi ,
I need help about the add-in templates. I did every step in this link https://forums.autodesk.com/t5/inventor-customization/inventor-2020-sdk-developer-tools-supported-vi...
but didn't work. I am using Inv2020 Vs(2017 and 2019). How can I see templates in vs?
JhoelForshav
Hi @Anonymous
If you've copied the file 'VBInventorAddInTemplate2020.zip' to 'C:\Users\<UserName>\Documents\Visual Studio 2019\Templates\ProjectTemplates\' It should be there. When you select the template for a new project in visual studio 2019, try setting Languages to "All Languages", Platform to "All Platforms" and Project type to "All Project Types".
I can only find the template with those filters.
I had to change
Tools>> Options>> Project and Solutions>>>locations
 thx for your help.
bradeneuropeArthur
I have put that in the main topic by mistake!!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
