Determine if A-Side Definition exists iLogic
Rob67ert
Rob67ert
I like to add an A-Side definition if there is none when i save my sheet metal part.
Is there a way te determine if an A-Side already exists with iLogic?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Rob67ert
Does anyone know how to solve this?
Robert
HermJan.Otterman
Hello Robert,
with this code (iLogic) you can get the "AsideStatus"
Dim smPart As PartDocument = Thisapplication.ActiveDocument
Dim oSMCompdef As Inventor.SheetMetalComponentDefinition = smPart.ComponentDefinition
MsgBox(oSMCompdef.ASideFaceStatus.ToString)
kASideDefault 106241 The A-Side face is determined by Inventor.
kASideSick 106242 The A-Side face is specified but invalid.
kASideUpToDate 106243 The A-Side face is specified and up-to-date.
(this is from the help)
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Rob67ert
Hi Herm Jan,
I was so close to it, the MsgBox(oSMCompdef.ASideFaceStatus.ToString gave me the correct answer.
Robert
HermJan.Otterman
great that I could help!
Herm Jan
