detect Content Center Part
bernd.schreck
bernd.schreck
I have written an add-in which loads a form for new parts and assemblies (to set naming, iProperties etc). The program is trigged by the app-event .OnNewDocument.
The problem I currently have is that I want to avoid loading my form at Content Center parts. For past loaded parts I could detect it easily by searching "Content Center" inside the FullFileName, but this is not valid for newly generated content center parts.
I´m able to detect the Content Center part by the assembly-event .OnNewOccurence (source: https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/content-center-file/m-p/9066906#M101877), but that is sadly trigged AFTER the OnNewDocument event.
Is there a way to detect the Content Center part during or before event OnNewDocument ?
Below excerpt of code:
'module
Dim oClass As TestEvenClass
Sub startEvent()
    oClass = New TestEvenClass
    oClass.ini
    Do While True
        DoEvents
    Loop
End Sub
'event class
Public WithEvents E_AssEvents As AssemblyEvents
Public WithEvents E_AppEvents As AssemblyEvents
Public Sub ini()
  E_AssEvents = ThisApplication.AssemblyEvents
  E_AppEvents = ThisApplication.ApplicationEvents
End Sub
        Private Sub E_AssEvents_OnNewOccurence(DocumentObject As _AssemblyDocument, Occurrence As ComponentOccurrence, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles c.OnNewOccurrence
            If BeforeOrAfter = EventTimingEnum.kAfter Then
                For Index = 1 To Context.Count
                    Dim oContextName As String
                    oContextName = Context.Name(Index)
                    If oContextName = "ComponentDefinition" Then
                        Dim oDef As ComponentDefinition
                        oDef = Context.Value(Context.Name(Index))
                        If TypeOf oDef Is PartComponentDefinition Then
                            Dim oPartDef As PartComponentDefinition
                            oPartDef = oDef
                            If oPartDef.IsContentMember Then
                                'this is a part from content center in standard way
                                MsgBox("This is a part from Content Center ")
                            Else
                                ' check if it is common part of custom part of Content Center
                                Dim isCustomPart As Boolean
                                isCustomPart = False
                                Dim oPropertySets As PropertySets
                                oPropertySets = oPartDef.Document.PropertySets
                                Dim oEachProSet As PropertySet
                                Dim oEachP As [Property]
                                For i = 1 To oPropertySets.Count
                                    ' use the 6th propertyset of [ContentCenter].
                                    ' If it is a Custom part, there is only one property within this property set.
                                    ' The name is “IsCustomPart”. While if it is a Standard CC part, there are some properties
                                    ' to indicate the information of the CC such as family, member etc..
                                    'the internal name of this propertyset is not same across different content center part
                                    'so, it looks we have to use display name, which assumes no user defined property set with the same name.
                                    oEachProSet = oPropertySets(i)
                                    'If oEachProSet.InternalName = "{5E21919D-4082-492A-8A30-039424CD07B5}" Then
                                    If oEachProSet.DisplayName = "ContentCenter" Then
                                        For k = 1 To oEachProSet.Count
                                            oEachP = oEachProSet(k)
                                            If oEachP.Name = "IsCustomPart" Then
                                                Dim oValue As String
                                                oValue = oEachP.Value
                                                If oValue = "1" Then
                                                    isCustomPart = True
                                                    Exit For
                                        Next
                                    If isCustomPart Then
                                        Exit For
                                Next
                                    MsgBox("This is a custom part from content center")
                                Else
                                    MsgBox("This is a common part")
                Next
        End Sub
        Private Sub E_AppEvents_OnNewDocument(ByVal DocumentObject As Inventor._Document, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles E_AppEvents.OnNewDocument
            If DocumentObject IsNot Nothing Then
                If DocumentObject.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or DocumentObject.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                    If InStr(DocumentObject.FullFileName, "Content Center") = 0 Then
'Init and call of program
'olib = New Init(oInvApp)
                        'olib.Main()
End Sub
JelteDeJong
you can have a go like this:
            If (DocumentObject.DocumentType = DocumentTypeEnum.kPartDocumentObject) Then
                Dim def As PartComponentDefinition = DocumentObject.ComponentDefinition
                ' This will not detect Custom CC parts.
                ' If you want to detect those you also need to check the iProperty sets
                ' see:
                ' https://adndevblog.typepad.com/manufacturing/2018/01/inventor-api-detect-a-content-center-part-is-inserted-as-standard-or-custom.html
                If (def.IsContentMember) Then
                    Return 'Stop doing any thing
                    'olib.Main()
    End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
bernd.schreck
Thanks for the reply @JelteDeJong .
Because the preview in Visual Studio does not show the ComponentDefinition object, I wasn´t aware I can access this, so thanks for this.
Sadly your solution does not work because (for whatever reason), the property IsContentMember is false for unsafed Content Center parts. After save it is true and even on the OnNewOccurence Event (trigged after this event), it is set to true when accessing the document object by Context.
Also looking into the PropertySets does not help.
Any ideas to solve this?
JelteDeJong
In your opening post, you have a rule that searches for 1 specific iProperty. With the following rule, I found more iProperties that hint at CC parts.
Maybe you are lucky and are those present other wise i would not know how to detect them.
Jelte de Jong
bradeneuropeArthur
For a CC part there is a additional propertyset available like content center. If that is available you have a cc part
Dim a As Inventor.PartDocument = ThisDoc.Document
For Each p As Inventor.PropertySet In a.PropertySets
	Logger.Info(" {0}", p.Name)
	Next
  • Inventor Summary Information
  • Inventor Document Summary Information
  • Design Tracking Properties
  • Inventor User Defined Properties
  • Content Library Component Properties
  • ContentCenter
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bernd.schreck
Hi @bradeneuropeArthur,
thanks for your reply. Sadly this is again only valid for already saved CC parts. New ones does only have the "normal" ones
carolien.depauw
Hi @bernd.schreck,
Maybe this code can help you?
ThisApplication.ActiveDocument.PropertySets.PropertySetExists("ContentCenter")
  • True when it is a content center part
  • False when it is not a content center part
ThisApplication.ActiveDocument.PropertySets.Item("ContentCenter").Item("IsCustomPart").Value
  • = 1 When it is a custom content center part
  • = 0 When it is not a custom content center part
