Design Assistant & OLE links
GosponZ
Message 1 of 14
GosponZ
We start to have problem with jpg's which we using as texture. They attached to models and drawings. We do have iLogics to remove them but what cause that to say new model few of them just attached and make problem. Is it here way to stop them to appear. Here is screen shot of what I'm talking.
Please ASAP if somebody know how to prevent this. Also it create new Library texture folder in Vault
Replies (13)
Message 2 of 14
bradeneuropeArthur
1 use the link button to remove them.
2 save as idw then save as dwg file or reversed should remove them.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 14
GosponZ
It is not problem to remove them. It is problem that they are start to att.to models. What cause this, and how to prevent of not happening? it is really annoying.
Message 4 of 14
bradeneuropeArthur
Vault seems to be re-attaching the items to the files!
Have you tried this button?
Have you tried to remove them without the vault add in loaded?
I will take a look if I can reproduce the problem and look for a solution.
For my understanding:
The items have been added manually by the engineer or how are they added (linked)?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 14
GosponZ
Start new part and jpg linked by itself somehow. That is my question  how this happening.
Message 6 of 14
GosponZ
Yes we remove them that is not problem to do. Problem is now on all files they linking them
Message 7 of 14
bradeneuropeArthur
What version of Vault
What version of inventor are you using
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 14
GosponZ
inv 2017
vault 2017 basic
Message 9 of 14
bradeneuropeArthur
All service packs are installed for inventor and vault?
Is your template kind of infected with the linked files already?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 14
GosponZ
Yes everything is ok all updates. It start happening few days ago. Never happened before, and that is why I alarmed.
Template infected hmm interesting but how to fix? Make another?
 Thank you for your effort to fix my problem
Message 11 of 14
bradeneuropeArthur
Yes try a new template.
Or take a look if the template already have linked files!
You can simply open the template file to take a look at. I do not mean create new file from template, but really open it from the template directory.
Let me know what you are there!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 14
GosponZ
Yes template was infected .ipt,. Removed and hope they won't come back. Still confused how they get infected.#@!
Thanks again for your help.
Message 13 of 14
bradeneuropeArthur
Sometimes it is to simple.... ha ha
Good to hear that it is solved.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 14
bradeneuropeArthur
Tip
Make your template folder protected!
Or at least readonly
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
