Derived solid visibility off - iLogic
Message 1 of 12
Hey,
Recently we have been receiving files that when the solid of the part is derived its appears translucent (refer to image below) and also this appears on a drawing, as well as looks very messy in an assembly. I have two questions, is there an ilogic i can use to turn of all solid bodies from a derived parts in an open assembly. And is there anything that i can do in the settings to hide these features in drawings?
Replies (11)
Message 2 of 12
IgorMir
Hi Grant,
Try to apply the View Filter first.
Cheers,
Web: www.meqc.com.au
Message 3 of 12
CCarreiras
Hi!
Question1: You can use "make components" tool in manage tab to turn multisolids into Assembly. Each solid will be a part.
Question 2, already awnswered above.
CCarreiras
Message 4 of 12
GKPByDesign
This only works at a part and or assembly level, i need this to work at the drawing level.
Message 5 of 12
GKPByDesign
The parts are created as serrate parts, and they used the derived surface bodies as reference, they do not create these using make components, i cannot change how these are made, as its external from this company, but i want to know if there is a quick way to turn them off, without having to go through every file.
Message 6 of 12
IgorMir
Well, I am not really sure what the issue is. Even if a derived surface is visible in the part itself - upon creating the view that surface is not visible in that view. Can you share an example of the issue?
Igor.
Message 7 of 12
The attached image on my first post shows a large derived pat, for a part that is 5% the size of what you see in the image, if you place this in a drawing, it shows the derived part in the drawing of the part that is 5% the size. Make sense? The part in the image is a smaller white plastic cover
Message 8 of 12
IgorMir
OK, the derived part has been created as a surface one and scaled up during the derive process. That's if I follow your description and the image you have posted earlier.  Without the actual file I can not add anything else to it.
Cheers,
Igor.
Message 9 of 12
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous if you are looking for an iLogic snippet this might help:
Set all surfacebodies to invisible. VBA code attached
iLogic - API access to Surface Bodies
Here are a few other good posts on how to turn the visibility off.
turn off a surface in drawing view
Globally turn off surfaces in idw views
Hiding Surface Bodies in Drawing views by default?
The best might be to turn off all surfaces and create a Level Of Detail to reference from the drawing.
For iLogic inquiries post at Inventor Customization Forum for best results.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 10 of 12
From one of the post there were multiple codes, but they were VBA, how do i get this to become an iLogic ule?
Sub HideSurfacesInAsm()
'catch and skip errors
On Error Resume Next
'define the active assembly
Dim oAssyDoc As AssemblyDocument
Set oAssyDoc = ThisApplication.ActiveDocument
Dim oSurfacebody As WorkSurface
Dim Vis As Boolean
Dim result
result = MsgBox("Make all surfaces visible?", vbYesNoCancel)
Select Case result
    Case vbYes
        Vis = True
    Case vbNo
        Vis = False
    Case vbCancel
        Exit Sub
End Select
Dim oDoc As Inventor.Document
For Each oDoc In oAssyDoc.AllReferencedDocuments
    For Each oSurfacebody In oDoc.ComponentDefinition.WorkSurfaces
        oSurfacebody.Visible = Vis
    Next
Next
ThisApplication.ActiveDocument.Update
End Sub
Message 11 of 12
Lewis.Young
This should work with iLogic now:
SyntaxEditor Code Snippet
Sub Main()
Dim Vis As Boolean
Dim result
Select Case result
    Case vbYes
        Vis = True
    Case vbNo
        Vis = False
    Case vbCancel
        Exit Sub
End Select
    Next
Next
End Sub
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
3ds Max 2018
Message 12 of 12
emanuel.c
Updated to work from Part Document also:
Sub Main()
	Dim Vis As Boolean
	Dim result = MessageBox.Show("Yes" & vbCrLf & "No - Turn Visibility OFF" & vbCrLf & _
		"Cancel - Exit", "Make all surfaces visible?", MessageBoxButtons.YesNoCancel)
	Select Case result
	    Case vbYes
	        Vis = True
	    Case vbNo
	        Vis = False
	    Case vbCancel
	        Exit Sub
	End Select
	Dim oDoc As Inventor.Document = ThisApplication.ActiveDocument
	DocType = oDoc.DocumentType
	If DocType = DocumentTypeEnum.kAssemblyDocumentObject Then
		    Next
		Next
	Else
		    Next
End Sub
