iLogic - API access to Surface Bodies
How can I distinguish between Solid Bodies and Surface Bodies?
In my case I want to get the Surface Bodies only (and just the actual surface)
If I use SurfaceBodies it seems to control both Solid Bodies and Surface Bodies and if I use WorkSurfaces then nothing seems to happen.
Please see snippet below for a very simplified example.
Dim oDoc As Inventor.Document
oDoc = ThisDoc.Document
    For Each oWS In oDoc.ComponentDefinition.SurfaceBodies
    'For Each oWS In oDoc.ComponentDefinition.WorkSurfaces
    'oWS.Visible = False
    oWS.Visible = True
    Next
GeorgK
Sub HideSurfaces()
'catch and skip errors
On Error Resume Next
'define the active assembly
Dim oAssyDoc As AssemblyDocument
Set oAssyDoc = ThisApplication.ActiveDocument
Dim oSurfacebody As WorkSurface
Dim Vis As Boolean
Dim result
result = MsgBox("Make all surfaces visible?", vbYesNoCancel)
Select Case result
    Case vbYes
        Vis = True
    Case vbNo
        Vis = False
    Case vbCancel
        Exit Sub
End Select
For Each oDoc In oAssyDoc.AllReferencedDocuments
    For Each oSurfacebody In oDoc.ComponentDefinition.WorkSurfaces
        oSurfacebody.Visible = Vis
    Next
Next
ThisApplication.ActiveDocument.Update
End Sub
It is a fine piece of code. I have seen it here on the forum, but it does not seem to work on the files that I have.
The files that we have here are imported files from a sub-supplier which we are using in some of our "as-built" documentation.
I have made an example file with the code, see attached files.
See also picture for Surface Bodies that I want to work with.
Boorda
You were already very close. All you needed to do was check to see if the IsSolid property was set to false.
Here is a sample that selects only surfacebodies, turns them visible and adds them to the documents selection set.
Public Sub SelectAllSurfaces()
    'Get the active document.
    Dim ActDoc As Document: Set ActDoc = ThisApplication.ActiveDocument
    'Lets check to make sure we are in a part or assembly document.
    If ActDoc.DocumentType = kPartDocumentObject _
    Or ActDoc.DocumentType = kAssemblyDocumentObject Then
        'Do Nothing, we can continue...
    Else
        MsgBox "This funtion can only be performed on a part or assembly document.", vbInformation
        Exit Sub
    'Create a select set to hold the selection.
    Dim SelSet As SelectSet: Set SelSet = ActDoc.SelectSet
    ActDoc.SelectionPriority = kBodySelectionPriority
    'We know we are working with a part or assembly file so lets grab its component definition.
    Dim cDef As ComponentDefinition: Set cDef = ActDoc.ComponentDefinition
    'Get the surfacebodies for the current document.
    Dim SrfBod As SurfaceBody
    Dim SrfBods As SurfaceBodies: Set SrfBods = cDef.SurfaceBodies
    'Lets add the surfacebodies to the selection set.
    For Each SrfBod In SrfBods
        'We only want surfaces that are not also solids.
        If Not SrfBod.IsSolid Then SelSet.Select SrfBod: SrfBod.Visible = True
    Next
End Sub
After running the above code.
Selected Surface Bodies Only
Automation is key!
Thanks for the reply. Perfekt.
I realize that this is an old post; but when I try the above code in Inventor 2016 it doesn't work.  I get an error on the line:
