ilogic pdf rule
ilogic pdf rule
ilogic pdf rule
Hi all,
At the moment i am looking for a solution to save pdf files from the idw files with a ilogic rule.
This rule, as shown, is used at the moment but has no functionality to create a path on a different harddrive in our network, with the same folder structure as the folder structure of the idw file. With this rule all the pdf files are saved in the same folder: J:\PDF_Files_Inventor.
For example a idw file is located here in the workspace: C:\VaultWorkspace\Designs\2014\1410\18871\example.idw I would like that the ilogic rule creates new folders on the J drive like: J:\2014\1410\18871\example.pdf
oPath = "J:\PDF_Files_Inventor"
oFileName = ThisDoc.FileName(False) 'without extension
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
'get PDF target folder path
oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF_Files_Inventor"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Can anyone give me tips to make this rule more advanced.
Marco
GosponZ
response = MessageBox.Show("Did you change path in this rule?", "Reminder",MessageBoxButtons.YesNo)
If response = vbNo Then Exit Sub
'Save PDF with options
'FileName = ThisDoc.FileName(True)
'ThisDoc.Document.SaveAs(FileName & (".pdf") , True)
oPath = ThisDoc.Path
PN = iProperties.Value("Project", "Part Number")
'path_and_namePDF = ThisDoc.Pathandname(False)
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oOptions.Value("All_Color_AS_Black") = 1
'oOptions.Value("Custom_Begin_Sheet") = 1
'Set the destination file name
oPath = "N:\Your desired folder
oPath = InputBox("Replace Path","New Path")
oDataMedium.FileName = oPath & "\" & PN & ".pdf"
'Publish document
 'Confirmation message
 MessageBox.Show("PDF SAVED TO: " & oDataMedium.FileName, "PDF Saved", MessageBoxButtons.OK)
On Error Goto handlePDFLock
'Publish document.
Call oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Exit Sub
handlePDFLock:
MessageBox.Show("PDF could not be saved, most likely someone else has it open", "No PDF for you " & ThisApplication.GeneralOptions.UserName & "!")
Resume Next
handleXLSLock:
MessageBox.Show("No XLS", "iLogic")
Resume Next
 Try this one. I'm using every day working for me.
rossano_praderi
Hi Marco,
i would like to give you an alternative solution
' alternative oFileName value
oFileName = ThisDoc.PathAndFileName(False).Replace(ThisDoc.WorkspacePath(), "J:")
' your code.....
' oFolder
oFolder = oFileName.Replace(ThisDoc.FileName(False),"")
' your code....
' oDataMedium.FileName
oDataMedium.FileName = oFileName & ".pdf"
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Hello Rossano Praderi,
Thank you very much for this alternative solution.
I have tried it out and it functions very well.
Best Regard,
Marco de Kort
