derived part material
Message 1 of 15
is it possible to get the material of the derived part in vba ?
Replies (14)
Message 2 of 15
jdkriek
I might be missing it, but I looked around the VBA locals and couldn't find material for the Derived part.
F8 through this code and look at locals (View > Locals Window)
Normally you'd find it under the Definition section...
Public Sub FindDer()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDerPartComp As DerivedPartComponent
    Set oDerPartComp = oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1)
    MsgBox ("Found " & oDerPartComp.name)
End Sub
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 3 of 15
Public Sub Derived_Material()
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim oderivedPart As DerivedPartComponent
    Set oderivedPart = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1)
    Dim oRefPart As PartDocument
    Set oRefPart = oderivedPart.ReferencedDocumentDescriptor.ReferencedDocument
    Dim oRefPartDef As PartComponentDefinition
    Set oRefPartDef = oRefPart.ComponentDefinition
    Dim oMaterial As Material
    Set oMaterial = oRefPartDef.Material
    MsgBox (oMaterial.Name)
End Sub
Message 4 of 15
jdkriek
That's interesting; the locals never show access to the material. I had originally assumed that it was accessed the same way as any other part, but Intellisense never picked it up and locals never dropped down to that scope in the definition.
Jonathan D. Kriek
Message 5 of 15
>>>jd & sassen....
thank you guys....
works perfectly....
Message 6 of 15
Formsprag
I see this post was solved in 2013, is it still applicable in 2020? I get an error when I try in to 2020. Any input would be helpful!
thanks
Message 7 of 15
Curtis_Waguespack
Hi @Formsprag
I did a quick test with Inventor 2020.
I ran this on a derived part and it showed me the material of the part from which it was derived without issue.
Just to confirm, the part referenced in your derived part is a part file rather than an assembly, right?
I hope this helps.
Curtis
Message 8 of 15
Formsprag
Yes it is a part file.
Here's the error I get.....
Message 9 of 15
Curtis_Waguespack
Hi @Formsprag
Ahh, okay the example posted in this thread was authored for VBA, so a bit of reformatting is need to run it in iLogic
Firstly, you can do a search for "Set" and just replace it with nothing, and then secondly you can just remove the "Sub..." and "End Sub" lines like this or make the Sub line read "Sub Main"
so basically here are two versions that will run via ilogic:
Public Sub Main
End Sub
or
I hope this helps.
Curtis
Message 10 of 15
Formsprag
Both ways worked perfectly! Thanks!
Could the code be tweaked so it would physically match the material from the parent rather the just display the parent in a message box?
Message 11 of 15
bradeneuropeArthur
You could vote one of my ideas in the idea station:
Derive I-properties!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 12 of 15
Curtis_Waguespack
Hi @Formsprag
I think this should do it.
I hope this helps.
Curtis
Dim sMaterial As String
sMaterial = oMaterial.Name
iProperties.Material = sMaterial
Message 13 of 15
Formsprag
That worked perfect! Thanks Curtis
Is there anyway to trigger the rule if the part is derived and ignored if not derived?
I tried to simply use the Event Triggers hoping the rule would be ignored if it didn't detect the parent file.
Message 14 of 15
Curtis_Waguespack
Hi @Formsprag
This will catch the error when there is no derived component reference and just exit the rule, so the while it will still be triggered, the rule wont error out.
I hope this helps.
Curtis
Try
Catch
	Return 'exit rule
End Try
Message 15 of 15
Formsprag
Perfect! Thanks for your help....
