Derived Assembly Into Part unresolved file reference
So I simplified an assembly into a part.
I copied the part with Save as (....,False) into various locations
But the part looses the reference to the original assembly it was derived from when I delete it from another assembly and replace it again.
I cant find a code that will either prevent this from happening or replace the file reference automatically, i dont want to open a file explorer window 60 times. like a famous post suggests to replace the file reference by selecting the file from a file explorer window.
its not replacing the reference but just not loosing it.
When I iterate though the referenced files the right file is always there but not active?
I just need to use resolve file and input the location of the file as a string but I can find the correct way...
I tried the following codes.
This one inside the derived part:
SyntaxEditor Code Snippet
Dim oDoc As PartDocument oDoc = ThisDoc.Document Dim oDef As PartComponentDefinition oDef = oDoc.ComponentDefinition Dim iLogicAuto As Object iLogicAuto = iLogicVb.Automation NewName_2A = "E:\Factory Components\Play Unit Components\Upright Spectrum\" NewName_2B = "Upright Spectrum.iam" Dim DP As DesignProjectManager Dim DPR As String Dim oDerAssemblyComp As DerivedAssemblyComponent Dim Full_File_Name As String Dim oDerAssemblyCompDef As DerivedAssemblyDefinition Dim Check As Boolean Dim File_Des As FileDescriptor For Each oDerAssemblyComp In oDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents Full_File_Name = oDerAssemblyComp.ReferencedDocumentDescriptor.FullDocumentName oDerAssemblyComp.SuppressLinkToFile = False 'Check = oDerAssemblyComp.ReferencedDocumentDescriptor.ReferenceInternalNameDifferent File_Des = oDerAssemblyComp.ReferencedDocumentDescriptor.ReferencedFileDescriptor DP = ThisApplication.DesignProjectManager DPR = DP.ResolveFile(NewName_2A, NewName_2B) MessageBox.Show(oDerAssemblyComp.Name & vbCr & Full_File_Name & vbCr & File_Des.FullFileName & vbCr & DPR) 'Either one of these with and without call???? Call File_Des.ReplaceReference(DPR) Call File_Des.ReplaceReference(NewName_1) Next
This other code from the assembly holding these derived Parts:
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document Dim oAsmDef As AssemblyComponentDefinition oAsmCompDef = oAsmDoc.ComponentDefinition Dim oDoc As Document Dim oOcc As ComponentOccurrence Dim userParams As UserParameters Dim param As Parameter userParams = oAsmCompDef.Parameters.UserParameters modelParams = oAsmCompDef.Parameters.ModelParameters Dim partDoc As PartDocument Dim oldFileName As String Dim NewName As String Location_Platforms = "E:\Factory Components\Modular Components\Single Module\Single Module\Spectrum Platforms\Spectrum Platforms - 1.ipt" Location_Upright_1 = "E:\Factory Components\Modular Components\Single Module\Single Module\Upright Spectrum\Upright Spectrum - 3.ipt" NewName_2A = "E:\Factory Components\Play Unit Components\Upright Spectrum\" NewName_2B = "Upright Spectrum.iam" For Each oOcc In oAsmCompDef.Occurrences If oOcc.ReferencedDocumentDescriptor.FullDocumentName = Location_Upright_1 Then MessageBox.Show(Location_Upright_1) partDoc = oOcc.Definition.Document MessageBox.Show(Location_Upright_1) Resolvedfile = ThisApplication.DesignProjectManager.ResolveFile(NewName_2A, NewName_2B) 'NewName = "E:\Factory Components\Play Unit Components\Upright Spectrum\Upright Spectrum.ipt" Call oOcc.ReferencedDocumentDescriptor.ReferencedFileDescriptor.Item(2).ReplaceReference(Resolvedfile) End If 'If occ.ReferencedDocumentDescriptor.FullDocumentName = Location_Platforms Then 'partDoc = oOcc.Definition.Document 'oldFileName = partDoc.FullFileName 'NewName = "E:\Factory Components\Play Unit Components\Spectrum Platforms\Spectrum Platforms.ipt" 'Call oOcc.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference(NewName) 'End If Next iLogicVb.UpdateWhenDone = True
This one to open from another file:
Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisDoc.Document Dim oAsmDef As AssemblyComponentDefinition oAsmDef = oAsmDoc.ComponentDefinition Dim iLogicAuto As Object iLogicAuto = iLogicVb.Automation Dim oOcc As ComponentOccurrence Dim Occurrences As ComponentOccurrences Dim oDoc_1 As PartDocument Dim Name_Upright As String Dim Name_Upright_1 As String Dim Name_Upright_2 As String Dim Name_Upright_3 As String Dim Name_Upright_4 As String Dim Name_Spectrum_Platforms As String Name_Upright = "Upright Spectrum" Name_Spectrum_Platforms = "Spectrum Platforms" Name_Upright_1 = Name_Upright + " - 1" Name_Upright_2 = Name_Upright + " - 2" Name_Upright_3 = Name_Upright + " - 3" Name_Upright_4 = Name_Upright + " - 4" Dim PFNL_List As New ArrayList Dim FNL_List As New ArrayList PFNL_List = MultiValue.List("Material_List_CO") FNL_List = MultiValue.List("Material_List_CT") Dim Location_Upright_1 As String Dim Location_Upright_2 As String Dim Location_Upright_3 As String Dim Location_Upright_4 As String Dim Location_Spectrum_Platforms As String For x = 0 To PFNL_List.Count - 1 If InStr(PFNL_List(x), Name_Spectrum_Platforms) > 0 Then 'MessageBox.Show(FNL_List(x), "SP") Location_Spectrum_Platforms = FNL_List(x) End If Next x For x = 0 To FNL_List.Count - 1 If InStr(FNL_List(x), Name_Upright_1) > 0 Then 'MessageBox.Show(FNL_List(x), "1") Location_Upright_1 = FNL_List(x) End If If InStr(FNL_List(x), Name_Upright_2) > 0 Then 'MessageBox.Show(FNL_List(x), "2") Location_Upright_2 = FNL_List(x) End If If InStr(FNL_List(x), Name_Upright_3) > 0 Then 'MessageBox.Show(FNL_List(x), "3") Location_Upright_3 = FNL_List(x) End If If InStr(FNL_List(x), Name_Upright_4) > 0 Then 'MessageBox.Show(FNL_List(x), "4") Location_Upright_4 = FNL_List(x) End If Next x 'MessageBox.Show(Location_Upright_1) oDoc_1 = ThisApplication.Documents.Open(Location_Upright_4, False) 'iLogicAuto.RunRule(oDoc_1, "Trigger Rule") NewName_1 = "E:\Factory Components\Play Unit Components\Upright Spectrum\Upright Spectrum.iam" NewName_2 = "E:\Factory Components\Play Unit Components\Upright Spectrum\Upright Spectrum.ipt" 'Call oDoc_1.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference(NewName) For i = 1 To 10 'MessageBox.Show(oDoc_1.File.ReferencedFileDescriptors.Item(i).FullFileName) If oDoc_1.File.ReferencedFileDescriptors.Item(i).FullFileName = NewName_1 Then MessageBox.Show(oDoc_1.File.ReferencedFileDescriptors.Item(i).FullFileName) Call oDoc_1.File.ReferencedFileDescriptors.Item(i).ReplaceReference(NewName_1) oDoc_1.Update Exit For End If Next i
Many thanks in advance!
