Deleting suppressed parts and assemblies
JorisSteurs1246
JorisSteurs1246
Does anyone has a some working Ilogic code or Vb to remove ,from an assembly and preferably sub assemblies, everything that is suppressed?
VinodBalasubramanian
Autodesk Support
Autodesk Support
Can you check the following thread and see whether it answers your query,
http://forums.autodesk.com/t5/inventor-general-discussion/how-to-delete-suppressed-components-by-ilo...
Hope it helps.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
JorisSteurs1246
Thanks , yes it works , on the top assy but gives an error when there are elements in a pattern suppressed. Besides that , it is definitly a timesaver.
Autodesk Support
Autodesk Support
Thanks. You could try this article on deleting a pattern through ilogic.
http://forums.autodesk.com/t5/inventor-customization/ilogic-delete-a-suppressed-component-pattern/td...
JorisSteurs1246
This is VBA code, I tried to run it as it is in Ilogic but it doesn't work.
I can't find any info about running VBA code from within an Ilogic rule.
Is that even posible or does the VBA code needs to be modyfied so that it can run as a rule?
