iLogic Code to Create Gears
ravikmb5
ravikmb5
https://www.youtube.com/watch?v=4zdu60I47DE
This code explains how to Create Involute Profile using 2D Equation Curves
This Code is also an Example for:
Creating User Parameters by Equations
Use of SketchEquationCurves
Creating points using IntersectWithCurve method
Creating Circular Pattern Feature
via API
Thanks to Brain Ekins and Adam for helping me to write this code
i have written this code with noexperience in programming
Please Let me Know for any corrections
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
Jon.Dean
Hi Ravi,
I copied your code straight into an iLogic rule and it worked perfectly; no errors.
Excellent.
Jon.
Jon Dean
ravikmb5
Here is an Link to Updated Code
https://www.dropbox.com/s/u61dma4j66zmz79/Spur%20Gear%20Involute%20Profile_Modified.docx?dl=0
Some times Dedendum Circle Diameter becomes more than Base Circle Diameter based on user inputs
so i updated this Code
Ravi Kumar MB,
