'Deleted Parameter Problem
Message 1 of 11
Hi everyone,
When i deleted one parameter(let's say myparam), on top of the rules which includes this parameters appears:
myparam = False'deleted parameter
After that when i add this parameter i have to get into rule and delete this line for each rule.
Is there any way to prevent this  ?
Replies (10)
Message 2 of 11
bradeneuropeArthur
Could you please share your code.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
Here is one of the rules:
Kaplama1 =False'deleted parameter (THIS IS THE LINE WHICH APPEARS AUTOMATICALLY, IF I DELETE THE USER PARAMETER Kaplama1)
If
Kaplama1 = True Dim oDrawDoc As DrawingDocument = ThisDrawing.Document ' Obtain a reference to the desired sketched symbol definition. Dim oSketchedSymbolDef As SketchedSymbolDefinition _ = oDrawDoc.SketchedSymbolDefinitions.Item("ElektrolitikÇinkoBağEl") Dim oSheet As Sheet = oDrawDoc.ActiveSheet 'create insertion point, coordinates - in cm ! Dim oTG As TransientGeometry = ThisApplication.TransientGeometry Dim oInsertionPoint As Point2d = oTG.CreatePoint2d(0.8,0.8) Dim oSketchedSymbol As SketchedSymbol _ = oSheet.SketchedSymbols.Add( _ oSketchedSymbolDef, _ oInsertionPoint, _ 0, 1, Nothing) Else Dim oDrawDoc As DrawingDocument oDrawDoc = ThisDoc.Document For Each oSymbol In oDrawDoc.ActiveSheet.SketchedSymbols If oSymbol.Name = "ElektrolitikÇinkoBağEl" Then oSymbol.Delete End If Next End If
Message 4 of 11
This is another one to clear all parameters. I don't think that it's because of the rule itself.
BTW all parameters are key.
Kaplama1 = False
Kaplama2=False
Kaplama3=False
Kaplama4=False
Kaplama5=False
Kaplama6 = False
KaplamaSonrası=False
Boya1=False
Boya2=False
Boya3=False
Boya4 = False
Boya5= False
Kaynak=False
Montaj=False
İsleme=False
Pah1=False
Pah2=False
Pah3=False
Pah4=False
Sertlik1=False
Sertlik2 = False
UpdateWhenDone =True
Message 5 of 11
bradeneuropeArthur
try this:
If Parameter(Kaplama1) = True
             oInsertionPoint, _
             0, 1, Nothing)
Else
		oSymbol.Delete
Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 11
I changed the rule, after that deleted parameter and open the rule again and result is same:
Message 7 of 11
bradeneuropeArthur
I see...
Try it this way:
Try
	p = Parameter.Param("Kaplama1")
             oInsertionPoint, _
             0, 1, Nothing)
	Catch
		MsgBox (False)
		oSymbol.Delete
Next
		End Try
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 11
It didn't appear but code is not working correctly. As you understand, code was placing sketch symbol into the drawing with only checkbox but not anymore.
Message 9 of 11
It is also adding sketch symbol no matter true or false, if i run the rule manually.
Message 10 of 11
If i switched my first line from
If Kaplama1 = True
To:
If Parameter("Kaplama1") = True
 'deleted parameter line don't appears however, code is not working directly with checkbox. I think i have to add another rule to execute all other rules.
Here is where i found the solution: https://forums.autodesk.com/t5/inventor-forum/deleted-parameter-remains-in-code/td-p/5236733
Message 11 of 11
This is the final code which is not working with directly check box. I have to execute with run rule.
			'Dim oDrawDoc As DrawingDocument
'To make sure that code is adding just one sketch symbol.
		oSymbol.Delete
	Next
             oInsertionPoint, _
             0, 1, Nothing)
Else
		oSymbol.Delete
Next
