data in content center for extranal souce, possible ?
Darkforce_the_ilogic_guy
Advisor Advisor
it is possible to get date from en excel  or sql database or somthing like that into and auto update in Content center
I would like to have the current price , and how many meters of the materiel are in stock .  it that possible to add an value into that change with information in other sourse change ?  it does not have to be an live update .... but maybe ones an day
WCrihfield
You can work with Excel and databases by code, but I don't believe you can update properties within the ContentCenter documents, because they are considered to be within a Library, which means they are write protected (read only).  You normally can't open parts from the ContentCenter, make edits/changes, then save the document again.  I don't have Vault, so I don't know if this works in a different way with that system.  Perhaps if you copied the file to a directory outside the ConentCenter, then ran your update code on it, then saved it, then moved the file back into the ContentCenter directory, it may work, but that sounds like it would take a long time and use a lot of system resources.
Wesley Crihfield
(Not an Autodesk Employee)
Content center is not 100 % .. but you have to setup your our read/write content center.. but I do not if it is possible to you write to the content centor form outside of the content center editor. or if the content center can read form other source .. like you can do in normal Excel. I do not need to be a live update ... ones a day or maybe ones a week might be find to help  us make better design choses  for cheaper contruktion , or faster production if that is the most importen factor....
What I want is to make a system that make accessing this infomation faster ..and in one place
WCrihfield
I wander if either of these two posts would contain any ideas that may help you any?
Create iProperties for all parts in Content Center
Change Content Center Parts to 'Purchased'
Wesley Crihfield
