CustomPanel - FlyOut
10:26 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I use the CommandControls.AddButtonPopup to have some buttons as a flyout. Now I think it does not work like the Autodesks one. I trie to explain it a litte bit:
By Autodesk -> for example IAM -> Place Component
- If you click to the Button the function to place a component is active
- If you click the arrow (e.g. place by vault) at the bottom the fly-out will expand
By API:
- If you want the first Flyout-Button you have to click to the first Button
- then the Menü is flying out
- then you can click the first Button
I thinks there sould be a better solution. So my question is: Is there any solution to have a flyout like the Autodesks ones?
Thanks a lot.
Christian
