port ilogic code to vb.net
hozz__
hozz__
I'm trying to port this function to vb.net and  get "Type not defined errors" when I try to declare the Asset and Asset Library object variables. My thought was that adding "Imports Inventor" to the header would be sufficient to get past the error, but no luck...apparently I'm missing a step that is likely right in my face, but I can't see it. Any guidance would be appreciated
Private Function GetAsset(oDoc As PartDocument, anAssetName As String) As Asset
	Try
	    GetAsset = oDoc.Assets.Item(anAssetName)
	Catch
        ' Failed to get the appearance in the document, so import it.
        ' Get an asset library by name.  Either the displayed name (which
        ' can changed based on the current language) or the internal name
        ' (which is always the same) can be used.
	Dim assetLib As AssetLibrary 'Type "AssetLibrary" defined error here
        assetLib = ThisApplication.AssetLibraries.Item("MG_Material")
        ' Get an asset in the library.  Again, either the displayed name or the internal
        ' name can be used.
        Dim libAsset As Asset 'Type "Asset" defined error here
        libAsset = assetLib.AppearanceAssets.Item(anAssetName)
        ' Copy the asset locally.
         GetAsset = libAsset.CopyTo(oDoc)
		 oWrite.WriteLine(vbTab & vbTab & Now & " -SUCCESS- Assigning asset """ & anAssetName & """")
    End Try
End Function
JamieVJohnson2
I copied your code into my VB development environment.  There are only 2 errors:
ThisApplication - replace with Inventor.Application acquired via some other method (such as invApp = Marshal.GetActiveObject("Inventor.Application"))
oWrite.WriteLine - this is a iLogic IDE exclusive tool, you can use
Debug.Print("some string value") or msgbox("some string value") instead.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
JamieVJohnson2
        Try
        Catch
            assetLib = invApp.AssetLibraries.Item("MG_Material")
            ' name can be used.
            Debug.Print(vbTab & vbTab & Now & " -SUCCESS- Assigning asset """ & anAssetName & """")
        End Try
    End Function
hozz__
My bad, I posted the iLogic code that I started with instead of the Vb.net code that doesn't work. I've already dealt with the issues you noted...
    Try
    Catch
	assetLib = App.AssetLibraries.Item("MG_Material")
        ' name can be used.
Dim libAsset As Asset libAsset = assetLib.AppearanceAssets.Item(anAssetName) ' Copy the asset locally. GetAsset = libAsset.CopyTo(oDoc) End Try End Function
The only code giving me errors in the IDE are the following two lines
Both the "Asset" and "AssetLibrary" declarations give me "Type is not defined" errors. My assumption is that I missed a reference in the header...
Imports System.Windows.Forms
Imports Inventor
Imports Inventor.UnitsTypeEnum
JamieVJohnson2
Imports Inventor is the correct item to have (you have it), if that is failing check project references for Autodesk.Inventor.Interop (Autodesk Inventor Object Library) (see my screen shot - using Inventor 2020.2.1).
hozz__
That got me to where I needed to be...I ended up removing and re adding the reference to Autodesk.Inventor.Interop and the errors went away...i expect I was likely referencing an old version of the assembly. thanks for your help Jamie!
