Custom table, with check off list
I'm trying to add a custom table to our .idw template.
The basic idea is I want a prompt to pop up when creating a new .idw that prompts the user to select several options.
Which would then generate a small table with checks and X'es.
The point is making it clear for production department, how to handle parts, ie. should they be deburred, painted, ect.
Depending on what fields were checked off.
Is there a way to make this happen?
johnsonshiue
Hi! This probably could be done using iLogic form and rule. If you could provide a specific example, forum experts can show you how to do that.
Many thanks!
Software Test Engineer
mcgyvr
Depending on your specific needs I might suggest simply editing your titleblock and manually drawing a table.. Then add static text like "painted", "deburred",etc.. in one column then add prompted entries next to it in the next column..
That would be the simple solution.. and you would be prompted to enter those when you started the drawing..
Ilogic requires programming skills and can be a much more advanced operation but could do more..
Please also let us know which version of Inventor you have in case someone wants to send you an example,etc...
