Custom iProperties global setting
first of all sry, I hope I can descripe the problem. I work in IT department and the Inventor Users asked me to find out how it works. Sry for English, I´m from Germany.
Problem is they have new name in iProperties. But they want the name be a global new name for every workstation. So it should appear on every machine in the dropdown list.
Just tried and read for one hour, but no solution. Still a lot of ??? here 🙂
Hope you can help me.
Kind regards
Owner2229
Hey, what dropdown list are we talking here about? A value in an iProperty? Something like this?
custom%20iproperties
Anyway, Inventors aren't connected together, so you'll have to save the values somewhere on your server. It can be a text file, database (e.g. SQL), (web) service, Inventor VBA project (If loaded from server, defaultly in "C:\Users\Public\Documents\Autodesk\Inventor 2017\Default.ivb"). Or you can copy it to every user on login, or manually (if you're sure it won't change).
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Yes, exactly this menu and the name property. Ok, lets say I want to use a textfile. Just write the name in it, for example "New Custom Name". And then, how to connect, that the name appears in the dropdown. Sry, but I never worked with Inventor, just the poor IT guy who got to find a solution 😉
