Update an assembly rule from a part file
10:27 AM
So I found a way to run a rule from the part level and that would be to open a new instance of the assembly and open the rule that way. There has to be some other way to get the rule to trigger.
Simply put, there is a rule to change the placement of a brace in the sub-assembly. When the part updates, it blows the brace out to the wrong spot. To update it, I have to run the rule in the assembly again so that it can update the parameters it receives from the part.
So my question: Is there a way to trigger a rule when a part in the assembly is updated? The part is named the same as the assembly if that helps.
