CUSTOM IPROP TO SHOW USING VBA
hi
id like to know if i can check using msg box in vba, if a certain name in custom iproperties already exist.
thanks
jdkriek
This should do the trick:
Public Sub cPropCheck()
	Dim oDoc As Document
	Set oDoc = ThisApplication.ActiveDocument
	Dim customPropSet As PropertySet
	Set customPropSet = oDoc.PropertySets.Item( _
	"Inventor User Defined Properties")
	Dim iProp As Property
	Dim sName As String
	' Define name here
	sName = "MyCustomProp"
		For Each iProp In customPropSet
			If iProp.Name = sName Then
				MsgBox (sName & " already exists")
			End If
		Next iProp
End Sub
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
>>>>jd
thanks a lot again !!!!  Smiley LOL
jdkriek
You're welcome 😉
Jonathan D. Kriek
jdkriek
If you want both status you will need to use a boolean and stop the loop:
	Dim sName As String
	' Define name here
	Dim Status As Boolean
	Status = False
				Status = True 'Prop Exists
				Exit For 'Stop Loop
			End If
		Next iProp
	MsgBox (sName & " exists " & Status)
End Sub
Jonathan D. Kriek
>>>>>>>>>jd
thank you so much again!!!Smiley Happy
