iLogic: Generate shrinkwrap of an IAM
is it possible to do something like this but to create an shrinkwrap of an IAM and save it as IPT?
Thanks!
Edited by
Discussion_Admin
jdkriek
See this thread: Shrinkwrap Using iLogic
You can also use the VBA example in Programming Help and convert to iLogic in minutes.
If you are still stuck, then let us know 😉
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
hi! thanks for your help, but I'm getting a lot of erros on VBA with the code taht you gave me. it does not recognize some of the code lines on VBA.
is it simple to pass to ilogic?
jdkriek
It IS very simple to pass to iLogic - which is basically VB.NET
Of course iLogic also has some nice shortcodes that you can use as well.
I usually use VBA to develop a script due to IntelliSense then convert to iLogic or straight VB.NET
Jonathan D. Kriek
