Custom Content center , how do I get all bolt into same group? material and length. and easy select when use bolt connection?
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 1
I have made a test in our custom library. I have create a few bolt. Some with diffent surface, other with diffent materiel.  I seens to have a problem with select a bolt that have a diffent material then change botl materiel if it does not have a bolt of the current length. and even if it have the same length .. I can only see the part number and file name  in Bolted connection component generator.  is the a way to get better information without have to create a family for each type of bolt ?
Replies (0)
