Coloring of certain parts including the assembly through ilogic
I have made a rule (from parts from the internet) that finds and colors parts in a big assembly. It does this by creating a layer and adding the lines of the part in that layer. It looks for a certain word of numbers that the user types in. then the user can select a color from a list (InputListBox). This all works but now i want to add the following:
I want the rule to also color (the same color) the assembly with contains the part. for example:
In the figure below it found and colored the orange part but I want it to also color the tube. they are in the same assembly so it can color the whole assembly or the tube allone, that does not matter to me.
The comlete code I use is this: (there is some dutch in it. If it is necessary i can translate it and post it again)
Sub Main() ' Get the active drawing document. Dim drawDoc As DrawingDocument drawDoc = ThisApplication.ActiveDocument Onderdeel = InputBox("Vul het AE of LI nummer in van de voetplaat (let op het is hoofdletter gevoellig)", "Onderdeel bevat woord", "LI0196") If Onderdeel = "" Then Exit Sub ' Have the user select a drawing view. Dim drawView As DrawingView MsgBox("Selecteer een View", , "Informatie") drawView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select View") Dim docDesc As DocumentDescriptor docDesc = drawView.ReferencedDocumentDescriptor '------------------------------------------------------------------------------beveiliging ' Verify that the selected drawing view is of an assembly. If docDesc.ReferencedDocumentType <> kAssemblyDocumentObject Then MsgBox("Het geselecteerde View moet van een assembly zijn.") Exit Sub End If '------------------------------------------------------------------------------beveiliging ' Get the component definition for the assembly. Dim asmDef As AssemblyComponentDefinition asmDef = docDesc.ReferencedDocument.ComponentDefinition ' Process the occurrences, wrapping it in a transaction so the ' entire process can be undone with a single undo operation. Dim trans As Transaction trans = ThisApplication.TransactionManager.StartTransaction( _ drawDoc, "Veranderen van kleur onderdelen") 'Aanmaken van de multivalue list in de samenstelling ----------------------------------------------------------------------- Dim oView2 As DrawingView view_naam = drawView.Name oView2 = ActiveSheet.View(view_naam).View Dim oModel As AssemblyDocument oModel = oView2.ReferencedDocumentDescriptor.ReferencedDocument oMyParameter = oModel.ComponentDefinition.Parameters.UserParameters oParameter = oMyParameter.AddByValue("Kleur", "Rood", UnitsTypeEnum.kTextUnits) Dim List(0 To 6) As String List(0) = """Rood""" List(1) = """Blauw""" List(2) = """Groen""" List(3) = """Geel""" List(4) = """Oranje""" List(5) = """Megenta""" List(6) = """Cyaan""" Dim oExprList As ExpressionList oExprList = oParameter.ExpressionList Call oExprList.SetExpressionList(List, False) oKleur = InputListBox("(Bij kruisje wordt alles terug gezet In de 'by standard' layer)", List, "Rood", Title := "Kies kleur", ListName := "Kies kleur") '-------------------------------------------------------------------------------------------------------------------------------------------------------------- ' Call the recursive function that does all the work. Call ProcessAssemblyColor(drawView, asmDef.Occurrences, Onderdeel, oKleur) ' Verwijderen van de aangemaakte parameters param = oModel.ComponentDefinition.Parameters.Item("Kleur") param.Delete trans.End End Sub Private Sub ProcessAssemblyColor(drawView As DrawingView, Occurrences As ComponentOccurrences, Onderdeel As String, oKleur As String) ' Iterate through the current collection of occurrences. Dim occ As ComponentOccurrence For Each occ In Occurrences 'msgbox(occ.Parent.Document.FullFileName) 'geeft het AE nummer van de samenstelling aan AE0106211 occParent = occ.Parent ' Check to see if this occurrence is a part or assembly. If occ.DefinitionDocumentType = kPartDocumentObject Then ' ** It's a part so process the color. ' Get the TransientsObjects object to use later. Dim transObjs As TransientObjects transObjs = ThisApplication.TransientObjects Dim drawDoc As DrawingDocument drawDoc = drawView.Parent.Parent ' Kleuren aan maaken Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveDocument Dim layers As LayersEnumerator layers = oDoc.StylesManager.Layers Dim oRed As Layer Dim oGreen As Layer Dim oBlue As Layer Dim oYellow As Layer Dim oCyaan As Layer Dim oMegenta As Layer Dim oOranje As Layer Dim oKleur_layer As Layer '---------------------------------------------------------- Rood On Error Resume Next oRed = layers.Item("Rood") If Err.Number <> 0 Then On Error GoTo 0 Dim redColor As Color redColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0) ' Copy an arbitrary layer giving it the name ' of the render style. oRed = layers.Item(1).Copy("Rood") ' the attributes of the layer to use the color, ' have a solid line type, and a specific width. oRed.Color = redColor oRed.LineType = kContinuousLineType oRed.LineWeight = 0.02 End If '---------------------------------------------------------- Groen On Error Resume Next oGreen = layers.Item("Groen") If Err.Number <> 0 Then On Error GoTo 0 Dim greenColor As Color greenColor = ThisApplication.TransientObjects.CreateColor(0, 255, 0) oGreen = layers.Item(1).Copy("Groen") oGreen.Color = greenColor oGreen.LineType = kContinuousLineType oGreen.LineWeight = 0.02 End If '---------------------------------------------------------- Blauw On Error Resume Next oBlue = layers.Item("Blauw") If Err.Number <> 0 Then On Error GoTo 0 Dim blueColor As Color blueColor = ThisApplication.TransientObjects.CreateColor(0, 0, 255) oBlue = layers.Item(1).Copy("Blauw") oBlue.Color = blueColor oBlue.LineType = kContinuousLineType oBlue.LineWeight = 0.02 End If '---------------------------------------------------------- Geel On Error Resume Next oYellow = layers.Item("Geel") If Err.Number <> 0 Then On Error GoTo 0 Dim yellowColor As Color yellowColor = ThisApplication.TransientObjects.CreateColor(255, 255, 0) oYellow = layers.Item(1).Copy("Geel") oYellow.Color = yellowColor oYellow.LineType = kContinuousLineType oYellow.LineWeight = 0.02 End If '---------------------------------------------------------- Cyaan On Error Resume Next oCyaan = layers.Item("Cyaan") If Err.Number <> 0 Then On Error GoTo 0 Dim CyaanColor As Color CyaanColor = ThisApplication.TransientObjects.CreateColor(0, 255, 255) oCyaan = layers.Item(1).Copy("Cyaan") oCyaan.Color = CyaanColor oCyaan.LineType = kContinuousLineType oCyaan.LineWeight = 0.02 End If '---------------------------------------------------------- Megenta On Error Resume Next oMegenta = layers.Item("Megenta") If Err.Number <> 0 Then On Error GoTo 0 Dim MegentaColor As Color MegentaColor = ThisApplication.TransientObjects.CreateColor(255, 0, 255) oMegenta = layers.Item(1).Copy("Megenta") oMegenta.Color = MegentaColor oMegenta.LineType = kContinuousLineType oMegenta.LineWeight = 0.02 End If '---------------------------------------------------------- Oranje On Error Resume Next oOranje = layers.Item("Oranje") If Err.Number <> 0 Then On Error GoTo 0 Dim OranjeColor As Color OranjeColor = ThisApplication.TransientObjects.CreateColor(255, 128, 0) oOranje = layers.Item(1).Copy("Oranje") oOranje.Color = OranjeColor oOranje.LineType = kContinuousLineType oOranje.LineWeight = 0.02 End If '---------------------------------------------------------- If oKleur = """Rood""" Then oKleur_layer = oRed Else If oKleur = """Blauw""" Then oKleur_layer = oBlue Else If oKleur = """Groen""" Then oKleur_layer = oGreen Else If oKleur = """Geel""" Then oKleur_layer = oYellow Else If oKleur = """Cyaan""" Then oKleur_layer = oCyaan Else If oKleur = """Magenta""" Then oKleur_layer = oMegenta Else If oKleur = """Oranje""" Then oKleur_layer = oOranje End If ' Get all of the curves associated with this occurrence. On Error Resume Next Dim drawcurves As DrawingCurvesEnumerator drawcurves = drawView.DrawingCurves(occ) If Err.Number = 0 Then On Error GoTo 0 ' Create an empty collection. Dim objColl As ObjectCollection objColl = transObjs.CreateObjectCollection() ' Add the curve segments to the collection. Dim drawCurve As DrawingCurve For Each drawCurve In drawcurves Dim segment As DrawingCurveSegment For Each segment In drawCurve.Segments objColl.Add(segment) Next Next Dim occName As String occName = occ.Definition.Document.FullDocumentName If occName.Contains(Onderdeel) = True Then ' Change the layer of all of the segments. Call drawView.Parent.ChangeLayer(objColl, oKleur_layer) End If End If On Error GoTo 0 Else ' It's an assembly so process its contents. Call ProcessAssemblyColor(drawView, occ.SubOccurrences, Onderdeel, oKleur) End If Next End Sub
Thanks in advance,
Frank
