Listing the contents of an ObjectCollection
oransen
oransen
As far as I can tell, once I have a RectangularOccurrencePattern I can get its inpiut components using ParentComponents. In C# (must be similar in VBA)
RectangularOccurrencePattern RecOccPat = (RectangularOccurrencePattern)OccPattern;
ObjectCollection Objs = RecOccPat.ParentComponents;
 But I can't find any help in how to loop over the ObjectCollection and listing the Parts or Assemblies it contains.
A longer example:
                if (OccPattern.Type == ObjectTypeEnum.kRectangularOccurrencePatternObject)
                    int iObjCount = 0 ;
                    foreach (Object O in Objs)
                        ABSup.Log.WriteLn(CLog.Type_e.ekLog, "   ",iObjCount.ToString(),"  ",O.GetType().ToString()," ",O.ToString());
                        // Crashes here, the cast is not valid
                        ComponentOccurrence CompOcc = (ComponentOccurrence) O;
                        if (CompOcc != null)
                            ABSup.Log.WriteLn(CLog.Type_e.ekLog, "     Component occurrence");
                        iObjCount++;
Does anyone know how to interrogate object collections?
Is my logic or reasoning incorrect?
jjstr8
I don't see anything wrong.  I can't duplicate your issue.  I'm not sure anything but ComponentOccurrence can be in the ParentCollection.  What's in the pattern?  If you want it to be bulletproof, use one of the following:
// Using a simple check
if (O is ComponentOccurrence)
// Using pattern matching
if (O is ComponentOccurrence CompOcc)
     // ... do something with CompOcc
// Using the 'as' operator
ComponentOccurrence CompOcc = O as ComponentOccurrence
oransen
What an idiot I was...thanks!
jjstr8
What was the issue?
oransen
As you said, I was not looking at or checking the type of the object, and in my IAM I has some patterns within patterns, which obviously could not be converted to an occurrence of a part...
jjstr8
Aha!  I hadn't thought of patterns in patterns.  If that's the case, you may have to traverse it recursively.
